Intel core i5 2300 2.8ghzPlease post your ENTIRE system spec including PSU make and model.
As a first port of call, please see this guide and go through each step thoroughly (without skipping) even if you have already done them, as this really does solve 90% of problems and a triple check never hurts:
https://forums.tomshardware.com/threads/perform-these-steps-before-posting-about-post-boot-no-video-problems.1285536/
GTx 960 gpuBumping isn't allowed.
I had covered the first steps.
CPU: 2300
PSU: LMS Power 750W
RAM: ?
Motherboard: ?
Storage drives: ?
GPU: ?
Have you covered everything in the guide completely including inspecting the CPU/Socket for bent pins?
Following that, my understanding is the PSU is very poor quality, so could well be a culprit. Presumably this is an old build that has suddenly stopped working? If so, what happened leading up to it?
Well the system was running until I switched it off a couple of times. I did the paperclip test and the PSU is running. So what is the problem?How long had your system been running before this happened? I suspect your power supply has died.
The PSU has sparked and is no longer working 😧Days? Months? Years?
