Hi, really hoping someone can help because I've hit a brick wall. I'll try my best to explain the problem so please bare with me.
I built my PC myself about a year ago with no problems until now. About two weeks ago when I tried to turn it on it would just go into some sort of reset loop were the GPU would flash, all fans would rev and the LED's on the MOBO would flash. After repeatedly turning the PC on and off it booted up normally and everything was fine until I turned it off a few days later, same problem. Again after many attempts I got it to stay on and never turned it off for another few days.
So one day I felt brave and optimistic and tried to get to the bottom of it
Things I've tried
ASROCK Z370 Extreme4
i7 8700k
Gigabyte RTX 2080ti oc windforce
Vengeance LPX DDR4 2x8gb white
Corsair tx650m
2xSSD 1xHDD
Genuine Windows 1 0
can't remember the name of the CPU cooler but has been doing its job well for a while
Hope I've given enough info and been clear enough
Starting to think something is fried :-(
Help a fellow brother out
Thanks
Things I've tried
- Tried a totally different PSU, same problem
- Took out GPU, same
- Tried RAM in different slots, 1 stick only act, same
- Took all RAM out, PC sounded normal but no signal to monitor (this may be normal I don't know)
- Checked CPU pins, everything seemed fine, same
- Took MOBO battery out all night, when Ipressed the power button the next day the Fans no longer pulse they seem to just sit at 100% and that's still the case
i7 8700k
Corsair tx650m
2xSSD 1xHDD
Genuine Windows 1 0
Thanks
