No Signal on Monitors After CPU Upgrade
notthatsmart
6
Hello! I just replaced my old (FX4100) CPU with an AMD FX 8350 and now my monitors aren't getting any signal when I power the pc on.
The GPU is a GTX 660
The mobo is asus m5a97 le r2.0
The psu is 700w
Would REALLY appreciate some help!
UEFI is just the BIOS type. That doesn't mean you are using the most up-to-date BIOS.
I would put in the old CPU and update your BIOS firmware first then install the new CPU.
No the monitors just give me the "No Signal" thing and they were working fine before I upgraded to this CPU, I already have the asus uefi bios are there newer ones?
Alright, thanks guys I will try that!
