On February 6, 2014 11:39:33 AM, mesaritism wrote:
For anyone that this solution didn't work please take a look at your BIOS settings.
I have a dell T5400 work station and I had to set the on-board sound device to ON
through BIOS for it to work properly after installing a new graphics card.
I just replaced my old 8400 GS card with a new GT 730 card and also had a "suddenly-no-sound" problem, which resolved itself rather unexpectedly… and the "solution" proved to be, well, "bullsh*t" is a pretty good word for it, so hopefully by posting this it'll help others, ideally
before they spend hours trying different things, uninstalling/reinstalling things, and basically slowly losing their minds over this infuriating and seemingly inexplicable problem.
I replicated my friend's post up there ⇈ because it was his suggestion that led to my problem fixing itself, although maybe not quite the way he described it.
First, while all perfectly valid and logical, none of the solutions in this thread helped me for the simple reason that
everything I checked was still set correctly. So for example, my default sound output had
not switched to another device and was still set exactly as it always had been. Also, it wasn't anything that could be resolved either through control panel ( Windows' or NVIDIA's ), and wasn't something trivial like a volume set to zero, a muted setting, or an unplugged connector.
And, perhaps surprisingly in light of the post above I quoted, it
also wasn't an
Enabled setting set to
Disabled in the BIOS…
all sound settings in the BIOS were set to
Enabled!… and checking those were the reason I rebooted and entered the BIOS in the first place, as per our friend
mesaritism's suggestion.
Here's the kicker though: by simply entering the BIOS and screwing around a bit with one of the sound settings ( I don't even remember which one ), more specifically by simply toggling it from
Enabled to
Disabled then back to
Enabled again and rebooting the computer ( with the thought that I have to keep looking since their was nothing bizarre in the BIOS settings )… you guessed it… the sound magically came back, its return signaled by the distinctive sound of the Windows startup .WAV sound I know so well.
And I was obviously like "
WHAT?!? What the—!!". Something like that, or like this
only maybe not as colorful. So it would seem that simply entering the BIOS, toggling/untoggling a sound setting, saving, exiting BIOS, and rebooting did the trick.
As far as which sound setting it was exactly, my guess is it likely doesn't matter which one. I think that it's the process of entering the sound settings, toggling/untoggling something (anything), then choosing the SAVE & EXIT option itself that does the trick, serving to somehow re-set ( in the sense of setting again ), or maybe reinitialize is a better word, all the
Enabled settings. One possibility is that one or more settings were indeed
Disabled by the whole process of installing a new graphics card,
despite still appearing as Enabled in the BIOS ( grasping at straws here but stranger things have happened ) and what I did "officially" re-enabled them all. I know that, logically, that doesn't make sense, because simply rebooting the PC
without going into BIOS should accomplish that… but the fact is it didn't, because before going into BIOS I had rebooted 3x
at least while trying other, more normal solutions from within Windows.
Oh… the new card works great.
