No sound. I installed a Hauppague TV tuner. After connecting it to the PCIe slot, the sound wouldn't work. I can see the green bar go up and down.
OS: Win8.1
MB: Gigabyte Z87X-HD3, integrated sound card. Realtek Audio
Attempts so far: Mute is off on both the computer and the program. Sound it turned up. Audio jack is in the correct spot (green). Speakers work with other inputs. Deleted driver - restarted. Reinstalled driver - restarted. Updated windows- restarted. TV tuner card removed-restarted. Went into BIOS and disabled the integrated sound card- restarted. Then enabled it and restarted. Short of a new MB, any other ideas? Thank you.
OS: Win8.1
