Archived from groups: microsoft.public.windowsxp.hardware (
More info?)
I have a similar problem with my Dell Optiplex with WinXP Pro SP2 and
Turtle Beach Santa cruz sound card. I think the problems started after
SP2, but I can't be sure.
Often, I'll get very low volume & static from my left speaker which
runs through a receiver/amplifer. All other rec inputs work OK with
this speaker.
I found a strange way to correct it (temporary) by opening sounds in
control panel & playing a fairly loud file like chord. Sometimes this
will force the "connection", and the sound will be OK for minutes to
hours.
Sometimes, the computer will just reboot, & MS crash analysis will
call it a driver or RAM problem. I have the latest drivers for Turtle
Beach, and I'm about to rip the card out & return to the MB sound chip
(yes, it's turned off in BIOS).
Yes, I've done all the plug/cable twisting & swapping with no avail.
Thanks for listening.
Richard
On Sun, 19 Sep 2004 08:09:05 -0700, "Roger"
<Roger@discussions.microsoft.com> wrote:
>THis post is so old, I'm sure you have teh problem fixed by now. But...I had
>a similar problem. It was software related. I uninstalled all, and I mean
>ALL, the audio software I had, rebooted, reinstalled, and BAM...worked fine.
>Hope your problem is, or will be, fixed soon.
>"Sharon F" wrote:
>> On Fri, 30 Jul 2004 10:11:21 +0300, neuman wrote:
>> > Hello,
>> > I have a relatively new machine running XP Pro (P4 2.8G, Asus P4P800
>> > motherboard).
>> > For some strange reason, sound only comes from one speaker. I've tested both
>> > the onboard Soundmax sound card and a Creative PCI sound card.
>> > All settings appear to be correct (inlcuding the balance....).
>> > Any ideas?
>> > Thanks
>> Did you set up the speakers in Control Panel> Sounds and Audio? Many
>> speaker settings on the Volume page. Select the type of speakers under
>> Advanced. A default install of XP sets this up very conservatively and the
>> user should adjust it.
>> Sharon F
>> MS-MVP ~ Windows XP Shell/User
