Archived from groups: microsoft.public.win98.gen_discussion (
More info?)
Truly, I defer to Brian A. & Terhune, who I'm sure will come out of
retirement if there or climb out of an earthquake even. Nevertheless...
What exactly happened to cause you to say "I have been unable to obtain
the needed info on the drivers"?
Here is basically all I know of audio, except you may also look at a
list of audio devices/drivers in Device Manager. If you go that way,
BETTER be sure of what you've got now, so that you may change back to
it. To see what you've got now...
(a) "Control Panel, System, Device Manager tab, Sound Video & Game
Controllers branch".
(b) D-Clk the devices under it, each in turn, for Properties.
(c) Click the Driver tab, & then click the "Update Driver button".
(d) Bolt "Display a list..", & click "Next".
What shows up in the "Models" box?
(e) Finally, bolt "Show all hardware".
What is lit up in both the left & right panes?
That is what is currently installed & active. If you choose others from
the left/right panes (& click "Next"), it will constitute an uninstall
of the old & an install of the new. Well, here is all I know...
With the computer off, un/re-plug all audio wires.
Well, try "START, Run, CDPLAYER". It is simpler than, for instance, WMP.
If you get sound there, then it's a setting in WMP, or whatever, at
fault.
(1) Is the sound muted? D-Clk the speaker icon in the Tray to see. If no
speaker is there, then "START button, Settings, Control Panel,
Multimedia", & check the box for it at bottom.
(2) "Control Panel, Add/Remove Programs, Windows Setup tab, Multimedia,
Volume Control". If it is shown as installed (checked), then uncheck it,
OK your way out, & even perhaps reboot. Then, do it all again, but this
time CHECK it.
(3) In my case, the volume control appears to be part of my audio
drivers...
When I do the following procedure, I am asked to supply drivers during
boot. I bypass the request, & end up with none. Then, I run an .exe
downloaded from Compaq, which puts them back in. Or, I go to a folder &
click a Setup.exe in there, when I want the older drivers.
The point is-- YOU may have to do it that way too. So, prepare.
(a) Boot to Safe Mode. (Enable Startup Menu at "START, Run, MSConfig,
Advanced button.)
(b) "Control Panel, System, Device Manager tab".
(c) Open the "Sound, video & game controllers" branch, & delete all
devices under it. This is meant to eliminate "ghosts" of drivers past,
which are invisible in Normal Mode.
(d) Reboot to Normal Mode.
(e) Install your Sound Drivers, if they haven't automatically been
detected.
(4) If you are sure of Audio drivers you may have downloaded, that you
do have a method to reinstall them, then consider...
(a) "Control Panel, Add/Remove Programs, Install/Uninstall tab"
(b) If your Audio driver is mentioned there, uninstall it before
installing the new.
Thanks or Good Luck,
There may be humor in this post, and,
Naturally, you will not sue,
should things get worse after this,
PCR
pcrrcp@netzero.net
"inquisitive1" <inquisitive1@discussions.microsoft.com> wrote in message
news:62EFE612-6D80-4C8A-9BF1-9F83F8A053E7@microsoft.com...
| I have been unable to obtain the needed info on the drivers. I guess
they are
| too old! Any suggestions for a cheap sound card?
| lecurry
| "PCR" wrote:
| > Huh?
| > PCR
| > pcrrcp@netzero.net
| > "Brian A." <gonefish'n@afarawaylake> wrote in message
| > news:eXGPVr$rFHA.1204@TK2MSFTNGP15.phx.gbl...
| > | "PCR" <pcrrcp@netzero.net> wrote in message
| > | news:ep3qoD3rFHA.908@tk2msftngp13.phx.gbl...
| > | >Now that
| > | > Terhune has finally mellowed, do your best to dissuade him of
| > retirement
| > | > & falling into earthquakes!
| > | No need to, I belive you have awoken the "sleeping" giant.
| > | Brian A. Sesko { MS MVP_Shell/User }
| > | Conflicts start where information lacks.
| > | http://basconotw.mvps.org/
| > | Suggested posting do's/don'ts:
http://www.dts-l.org/goodpost.htm
| > | How to ask a question:
http://support.microsoft.com/kb/555375
