I just removed my old thermal compound from my cpu and mounted back my noctua.
However,because I didn't mount the computer the first time, I'm thinking the fans where pointing in the wrong direction.
First, there is an arrow on the fans, I imagine that it means where the air comes OUT (so the air goes where the arrow points). Can someone confirm this to me?
Second, I imagine that each aluminium cooling fin to work correctly should be "cooled" by the fan. So every fan must have the arrow pointing to the fin, and both fans should point to "outside". Am I wrong here? I'm expecially not sure of this part, because I don't know if every fan should point to a fin (and both should point outside).
If that's the case, I have a problem because the hooked clips are mounted in the wrong direction, so how can I remove those, are there any guide or any suggestion? I tried removing them but it's quite hard and I don't want to break anything.
Thanks for any suggestion.
