I have a MSI 975X Motherboard.
1 SATA 250GB HD
1 IDE 200GB HD
1 DVD-WRITER
1 DVD-ROM
In the BIOS setting, SATA mode options are IDE/RAID/AHCI
On-chip SATA options are Disabled/Combined/Enhanced
If using SATA to run 1 HD, am I limited to use only 1 IDE port?
I would like to use SATA HD as primary master on SATA1.
IDE HD as Secondary Master and DVD-ROM as Secondary Slave on same IDE cable on IDE1.
DVD-Writer on Third Master on IDE2.
Is that possible? Please suggest the best configuration. Thanks.
1 SATA 250GB HD
1 IDE 200GB HD
1 DVD-WRITER
1 DVD-ROM
