Question NordVPN help request
very_452001
355
Hi,
Most sites actively block vpn's making vpn's useless where you got to disconnect from nordvpn to access the site.
Do sites block common Nordvpn servers ip addresses? I even use fresh new servers that recently been added to nordvpn's servers list but such sites still don't function properly.
I contacted NordVPN and their response is they add new servers all the time and advised to try them but they still dont work?
Those who use NordVPN: what best settings/tweaks shall I use to make sure all sites will open & work fully with no probs?
Hi,
uninstall.
Seriously Nord does not offer the ability to Whitelist websites. All you can do is try different servers, Turn off Cybersec, or try a different protocol type: UPD/TCP
But since yo have to get into the advanced menu, this takes more time to 'turn on' then simply disconnecting for x-minutes.
I've been using nord for about 3 years and still do.
Reactions: very_452001
uninstall.
Okay how does a vpn service offer whitelisting, is it only available via their dedicated ip service?
Do you know how to get into the advanced menu of NordVPN and what settings shall I use?
Which is better UPD or TCP for issues like this?
Finally which vpn is the best that offers whitelisting?
