I'm trying to figure out if the new system I've built is working in order. The water pump mounted to the cpu is actually missing a screw but it looks like it's giving it even power with the other 3 screwed in. The Glacer 240L was a pain to install I couldn't get the stands off so I had to mount it to the motherboard while I had someone else hold the radiator and using to much force broke a part off the backplate. Although, my games seem to be working fine. Rainbow Six gets 50-60 fps at 1440p Ultra Settings, even more fps in Fallout 4 Ultra, but sometimes I get like 100% CPU usage in games like H1Z1 and when I turn settings up in that game my frames drop to 10-20. In all my games my temperature is around 50-75 degrees celsius though, so does that mean it is cooling my CPU? Also I checked in the fans section in HWMonitor and there's only 4 fans that are in my case but I guess a watercooler doesn't count as that. Idk if my system would detect it in a device manager like program. What could be the source to the frames dropping in H1Z1 other than its an unoptimized game, my specs are very good I should have no problem running it?
