Novice user/Sound Card Troubles
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.general (More info?)
Greetings,hopefully someone can help me.But I'm affraid it is in vain 🙁.
I purchased a Logitech Surround System with HOPES my movies and Music would
sound BETTER.Thing is I'm affraid my Dells sound cards are NOT up to par.I
have 4 plug ins in back,but can only get the Subwoofer and 2 fronts to
work....Did I make a bad purchase? Or can I get an upgrade download
somewhere???
> 🙁. I purchased a Logitech Surround System with HOPES my movies and
> Music would sound BETTER.Thing is I'm affraid my Dells sound cards are
> NOT up to par.I have 4 plug ins in back,but can only get the Subwoofer
> and 2 fronts to work....Did I make a bad purchase? Or can I get an
> upgrade download somewhere???
We can't really answer you without knowing what sound card you have.
Look in Device Manager (System applet in Control Panel) and see what
the sound hardware is, or look on the paperwork that came with the
system. Post back with that information for more help.
Malke
MS-MVP Windows User/Shell
Elephant Boy Computers
www.elephantboycomputers.com
"Don't Panic"
If you purchased a low end Dell system, and did not change the sound card option, there is
no sound card. Although there are 4 jacks, it is integrated audio from a chip on the
motherboard, not a sound card. When I purchased my Dell, I chose the $25 upgrade for the
Sound Blaster Live card with 5 jacks, which when the icon is right clicked in the
notification area (formerly system tray), then left clicking Audio Properties brings up a
window where you can set speaker options for everything from no speakers to 7.1 Surround
Sound. If you DO have the integrated audio, it would not meet your surround sound needs.
You can easily disable the onboard sound, and install a sound card that will do what you
want. I've seen the Sound Blaster Live card in the low $30 range online:
http://www.cdw.com/shop/search/results.aspx?grp=SND
T.C.
t__cruise@[NoSpam]hotmail.com
Remove [NoSpam] to reply
"McCloed9" <McCloed9@discussions.microsoft.com> wrote in message
news:1999AE49-A049-44E5-804E-F2E87D49C5E3@microsoft.com...
> somewhere???
hi,
The sound card on the motherboard should have support for Surround stereo or
else you wont get this feature with the speakers.
Contact your manuals to see the type of sound card that it has and whether
it has support for stereo.
Regards
M. Rajesh
..Net and Windows Shell MVP
www.winxpsolution.com.
Windows MarketPlace Moderator
> somewhere???
4 Plugs usually mean at least a 4.1 system.
USUALLY... it's Front, Rear, Microphone, Digital Out OR Center/subwoofer.
I can tell you that if the plugs are colour coded, usually it's: front (left
& Right) should be green, the rear one's black, center/subwooter is usually
orange, Microphone is pink, digital out is blue.
If you bought a logitech Surround sound, you should have Green, Black and
Orange. If you have matching colours on your sound card, plug them in! Also
(MOST) logitechs have a switch on the back that determine whether it sends a
2.1, 4.1 or 5.1 signal to the speakers. Make sure you do the select the
correct configuration. The only thing else that I can think of is going into
the Audio settings in windows (Control panel > Sounds, Speech & Audio
Devices >Sounds & Audio Devices > Speaker Settings) and making sure Windows
knows what type of signal to send to your sound card.
That's about as much I can tell you without knowing what type of soundcard
you have or which logitech's you bought.
For reference, i have a Creative SoundBlaster Live! 5.1 hooked up to a set
of Logitech Z-5300 5.1 THX speakers.
Regards,
Lawrence Wong
"Malke" <notreally@invalid.com> wrote in message
news:u2b2B6KbFHA.3144@TK2MSFTNGP14.phx.gbl...
> Malke
> "Don't Panic"
Hi,I'm in the Sounds ,Speech Devices and I'll write down whats in front of me
in the Hardware...HL-DT-ST CD-RW GCE-8400B TYPE/ DVD/CD ROM
Samsung DVD-ROM SD-616T Type/DVD/CD ROM
Then it starts listing these Codecs...Unimodem Half Duplex Audio
Device,Creative SB Live Value (WDM),Creative SB Live Gameport Ect.
I'm greatful for the Help..I thought this Dimension 4500 was Top End...Guess
I was ripped off ...Thank You again,Take Care.
> Malke
> "Don't Panic"
Thank you,I did go into the Windows and changed it from 2 speakers to
Surround..Still nothing...Its a Logitech X-530 system,and I have 3 color
coated wires (Blk,Grn & Orange) On my Dell I have 4 Plugs Blk,Yellow and 2
Grn.I've updated ALL my Drivers,and I have a Samsung Sound Card,If thats any
help?..Thank You again,Take Care.
> Regards,
> Lawrence Wong
> > Malke
> > "Don't Panic"
Thank You...I've tried about EVERYTHING...Its a Dell Dimension 4500,I thought
It was top end,guess not...I went into the Sound,Speech devices and it had
several things listed under Hardware,Samsung ,and Codects (whatever those are
,lol)
Thanks again,I'll keep trying...Take care
> T.C.
> > somewhere???
