Review Nreal Air Review: Gaming and Media Greatness Marred by Dongle Madness
I find it a bit weird, and decidedly American, to regard "only usb-C" connectivity as a minus for the product to be reviewed. The future is usb-c, anyway. Also for IOS devices. The devices that do not support usb-c are the problem.
for now*
which is great yes. we do not know if it will be replaced eventually.
Also i found the headline laughable..
"but iOS users should be aware of added costs for adapters. "
because if you are an Apple user you already (and have been for what a decade?) are forced into adapter hell.
I guess I just don't understand why I should want to hardwire a display to my face.
It seems more like a skymall/sharper image gimmick than something that would improve my life in any way.
I'm wearing my nreal airs right now. It's great if you have a Samsung device with DEX or a steam deck not sure if it's worth it with iPhone since all you'll be able to do is mirror with a separate dongle and won't be able to turn off the phone screen. I think you can get a cheap S10 or Note 10 and use that instead of wasting you money on the adapter that has pretty limited functionality and is pretty bulky. With a Mac book you get 3 virtual screens so that's not too bad.
Did you find a way to charge your steamdeck + using a keyboard via usb while using your nreal airs? My usecase would be to do typing work on the steamdeck and not needing a Display, just the glasses and a keyboard
Haven't tried it with a steamdeck but with my S22 Ultra the redmagic USB dock works great for wired charging and a magsafe powerbank is good for on the go. I don't have any USB keyboards anymore to try out but all my bluetooth keyboards, mice and gamepads work just fine. I also use my full android smarwacth a customizable trackpad and keyboard to use while the phone is in my pocket. i suggest you check out the r/nreal subreddit for other questions
They support 3D movies at least on Android with the proper player installed. I've just used it a couple of times to try out but don't really have any use for it.
I purchased this Elebase HDMI Male to USB-C Female Cable Adapter, New or Used: https://www.amazon.com/gp/aw/d/B08VDT3YGK
And used it with this USB C to HDMI breakout:
https://www.amazon.com/gp/aw/d/B0836TZH5X
Using a power source with 2 USB you could probably make that work really easily and have a USB port free. I got a USB A to USB Micro 90° adapter to keep the dongles simplified.
You might be able to use a power splitter on the breakout USB to power the USB C injector and keyboard together.
I picked up a Logitech Bluetooth keyboard so YMMV.
It also works with the NXTWEAR G
