I have a pre-built MSI desktop that I recently purchased from CDW. It originally came with a SATA SSD as the primary drive, but I've replaced it with a Samsung 970 PLUS NVME drive in the M.2 slot. It works nicely, but according to the Samsung Magician app (and also HWMON) the temps on the M.2 drive are too high when it's under any kind of load.
At idle, it runs 43-46 degrees, which the Magician app says is "normal", but under load it can be anywhere from 52 up to 63 degrees Celsius. The Magician app calls this "Too High".
I've added an intake fan (a 120 mm Corsair maglev fan) pulling air in and blowing down onto the M.2 slot. Previously it was too warm even at idle as well as under load, but seemingly not as hot under load. Now with the extra fan, I get the temps described above. (I also swapped out two DIMMs for four at the same time, but I don't know if they generate a lot of heat.)
The MSI PC came with a heat sync ("M.2 FROZER" ) for the M.2 drive, which is, of course, installed.
Ambient temps in my home office are getting warmer in the afternoon as the weather warms up and the sun shines in, and I don't want to damage my M.2 drive by overheating it. So I have two questions:
Background:
The RTX3080 graphics card (the reason I bought a pre-built system) has a fan/fans that speed up and slow down dynamically. When the system first loads from a cold boot, the GPU fan tends to click a bit, but it stops that once it warms up.
The system includes a liquid cooling solution for the CPU.
Thanks in advance for any advice!
- How hot is really too hot? Should I be concerned?
- What else should I do to try and improve cooling of the drive? I could replace the 120 mm fan with a 140 mm one, and I could add a second fan in the top of the case, but I'm not sure how best to proceed.
Background:
