nzxt 340 vs nzxt full tower?? Please help :D
Pittama
Commendable
Apr 24, 2016
22
The question says it all. I know it's a huge price difference between them,but the thing is that in my country some random guy thinks the full tower is a 410 and I negociated with him and I can either buy the phantom full tower for 60$ or s340 for 70$ . Probably the full tower is better,but it's also much older. I can't find any comparisons,obviously haha,but I'm wondering if there is something about the full tower that I might want to consider.
Unless you're going to be stuffing a lot of heatware in the Phantom 410(which isn't a full tower, this is) or going with large radiators and only 3.5" drives than that would be the case to consider. If you're sticking to 2x2.5"+ 2x3.5" drives then the S340 is the route to go albeit the placement for a 5.25" drive is missing on it with an added bonus of having your closed loop cooler showed off inside it.
You should forgo the Phantom 410 if you don't intend to use optical drives(which is now a thing of the past).
