[SOLVED] NZXT Kraken z63, LL120 Fans
MCSwagEleven
17
Can the Kraken z63 be used with Corsair LL120mm fans instead of the stock non-RGB fans? Would they fit into the radiator properly? Which fan screws would I use?
1)No.
2)No.
3)None.
Z63 uses 140mm type fans.
But perhaps you actually meant using the LL140s, in which case:
1)Yes.
2)Yes.
3)Same ones the stock Z63 fans used.
It's a terrible idea though, because Corsair's LL series aren't radiator fans - with the exception of the 2000-2200rpm version of the LL120.
The other LLs don't have the muscle to move air into the chassis AND through the radiator... well, besides doing a push-pull sandwich, but that has it's own set of problems.
1)No.
2)No.
3)None.
1)Yes.
2)Yes.
1)No.
2)No.
3)None.
1)Yes.
2)Yes.
Okay so then if I was to use the Kraken z73 with those 2000-2200 rpm LL120 fans, it should work fine right?
