Nzxt Phantom 410 or the Corsair 600t? I need help, I cant decied
stokesmellor
30
So, when i first bought and built my gaming computer i made a silly mistake of buying a coolermaster silencio 550 which is a awful case. So after managing to get some spare money I decided that it would be best for me to get a new case, one that is fairly quite and that as good cooling. I then came across the wonder full NZXT Phantom 410 with nice styling and good space for cable managment and lots of fans. I thought this would be a good case to get since i can then buy some noctua fans to go in it. But after looking at reviews i noticed that the Corsair 600t was cooler with its stock fans. So i thought mabye i should buy that. But since it is quite a bit more expensive im not sure if i should go for it.
What should i do? Have any of you had any experiences with these cases?
Thanks in advance
-stokesmellor
(sorry for long thread)
Hmmm, i think i might go for the Phantom 410 since i have only bad experiences with cooler master and i do want some extra cash to spend on fans and other stuff. Thanks man.
Hmmm, but after looking at some review of the 600t i think it may be a bit more wise to get it since i will be able to fit a radiator for water cooling in it, unlike the phantom 410. Grrrr i cant decide!
Hmmm, im not too keen on the storm trooper too big for me and i dont like the design. But has that picture shows i think i shall go back to my original choice for the 410 since i can have some extra cash off it for more cooling unlike the storm trooper and 600t. I think my desision is final. Thank you once agian. Lol.
