Greetings all!
I received my order from Newegg last night, and here is what I got:
Case: NZXT Switch 810
Case Fans: 4x NZXT 140mm Enthusiast Series (+4 more NZXT 140mm stock case fans)
PSU: Corsair AX750
MB: Gigabyte GA-Z77X-UD5H LGA 1155
GPU: Asus Radeon HD 7850
CPU: Intel Core i5-2550k
CPU Cooling: Corsair H100
RAM: Corsair Vengeance DDR3 1600
Motherboard is mounted with all of the main components. I've connected the USB 2.0 cables, a SATA2 cable, the front panel Power connectors, etc. But one cable that I wasn't sure what to do with was this one:
http://media.bestofmicro.com/3/H/329309/original/nzxt_switch-810_usb3.jpg[img]
Apparently, this is the front-panel USB 3.0 internal connector, but on the motherboard booklet, I don't see a location to plug it into?
Greetings,
Please forgive the length of this message...
I purchased an NZXT Switch 810 PC case and four extra NZXT 140mm Enthusiast Series (non LED) case fans, in order to add etxra air flow to my case. However, I am having problems with installation, and the instruction manual did not help.
1) The Enthusiast fans come with 4x mini screws and 4x rubber grommets. How do you thread the rubber grommets into the fans? The fan case has closed corners, and the screw holes are too small for the grommets. Pliers/tweezers didn't work, as I couldn't fit them in either. See [url=http://ep.yimg.com/ca/I/svcompucycle_2206_187981061]http://ep.yimg.com/ca/I/svcompucycle_2206_187981061[/url] for an image explanation - my fans are like the fan casing on the right.
2) Do I need to buy a set of longer screws to mount 140mm x 25mm fans on the top (external) part of the Switch 810, if I have a Corsair H100 CPU cooler mounted at the top (internal) part of the case? The screws that came with the Enthusiast fans are too small to thread from the top (because they are "closed cornered" fan cases), but if I thread from the internal side of the case, it interfers with the H100 being mounted. I can ummount the H100, screw in the 140mm fans from the internal side of the case, and then re-mount the H100...but the screws from mounting the 140mm external fans 'raises' the H100, so that I can't screw it in.
3) What is the ideal method for routing fan cables from the top of the case, to the interior of the case, to the back cable-management area of the case (behind right side panel of case, if looking from the front)? I tried to feed the cables (fan speed switch + fan power cable) through the large holes intended for airflow, but the fans sit on top of the cables and graze the cable itself, which I can imagine is not a good thing to happen.
4) Has anyone come up with a way to mount individual fan switches (that come with fans) on the outside of cases? The Switch 810 comes with a fan speed controller, but it only has 7 slots, when the case houses 10 fans (not counting the extra 2 if going push/pull on the H100, bringing the total to 12 fans). So I was thinking of trying to find a way to get the invidual speed switches for the 4 extra Enthusiast fans that I bought mounted to the front or side of the case, so that I don't have to open the darned thing in order to adjust fan speeds. With all the cables (hopefully neatly, as soon as I read up on how best to accomplish cable management) on that side of the case, opening it would cause everything to "spill out"...I have a rat's nest right now, and the side panel doesn't even stay on, ;-(
Thanks all. Answer what you can, if you can, and if you feel up to it. I know it's a lot. I'm such a noob.
I hope someone can offer tips/advice/answers to these...I spent four hours last night trying to get everything running, and finally got tired at 2:30am and went to bed (with work at 7am). :fou:
PSU: Corsair AX750
Greetings,
