NZXT may just have a winner on its hands with its new case, the Noctis 450.
NZXT's Noctis 450 Case Updates H440 Design, Adds Features : Read more
The scheduled forum maintenance has now been completed. If you spot any issues, please report them here in this thread. Thank you!
Obviously this is just a plastic exterior shell with the same internals, and I must say it is ugly. I don't understand. Anyone with style knows that nothing else in your house has shapes like these cases except for maybe my Netgear Nighthawk router, but either way it just doesnt work well and you can clearly see its only purpose is to mask a perfectly normal case.
I doubt this will sell as well as the H440. This article mentioned aggressive which has NO place in the computer world haha. It is a computer...lets be honest
The styling is pretty aggressive, may appeal to some while not to others since it's all about taste. Nice to see they upgraded the fan hub. Still surprised to see a modern case with such restrictive fan mounting. Only up to 120mm's in the front and top? Many cases now are capable of 140mm, some even 200mm. For the price and considering they're saving money turning to plastic side panels I think they could have put a bit more thought into it. It's pretty simply to make a multiple mount platform that accommodates both 120mm and 140mm fans at the least.
Maybe it doesn't matter to others, but some may find it off putting that a rehash of an existing case, dropping metal for plastic comes with an even higher pricetag than the previous model by a good $30-40 depending on discounts.
does this not have a dvd/bluray drive bay?
The internal design of the case is actually identical to that of the H440, offering room for an ATX motherboard, thee dual-slot graphics cards up to 294 mm long with the hard drive cages installed
1. This is just do to each case layout. How the H440 is laid out and the overall size of the case depict on how much room there is for the GPU.
2. Same concept on both. You have a header from the PWM board that relays information to and from the motherboard. There is an external power connection so that you dont fry the motherboard at all. With AI Suite and other programs (depending on motherboards) you can adjust the fan speeds that are connected to the hub via PWM signal. Its rather simple and complicated at the same time. It will be some time before it does come to market.
3. Adding those items makes it not the H440. As the H440 stands it changed the game, and is causing other companies to play catch up and evolve. Sometimes those items arent needed with the way software and hardware is being approached.
