OBS: I record and video stutters with 144hz monitor
Geomini
13
Hey, so I've been having this problem when I record on OBS on a 144hz monitor and then if I go to the video recording starts stuttering. I normally record at 60fps and sometimes I'll record 180-240 fps.
My Monitor: http://www.bestbuy.com/site/msi-optix-27-led-curved-fhd-freesync-monitor/5773401.p?skuId=5773401
My PC specs:
- Nvidia GTX 970
- i7 processor
- 16 GB of ram
- 64 bit operating system
My OBS settings:
- http://imgur.com/a/7FslP
- http://imgur.com/a/YYA8s
- http://imgur.com/4SmuOQG
If you would like more information please ask.
My processor is Intel(R) Core(TM) i7-6700 CPU @ 3.40ghz
Also its the video that looks like it lags and not the actual things im doing.
Same difference: if the video encoder is falling too far behind because there isn't enough spare processing power to catch up with incoming frames, frames get dropped from the encoding pipeline to catch up.
I put my bitrate higher in OBS to 250000 and it barely helped, I think it's that it skips frames because the video records at 60fps but my monitor is at 144hz. I don't know that much about this type of stuff so correct me if I'm wrong.
- Another problem has happened is that when I change my monitor to 60hz it doesn't look like 60hz and it lags a little but I can try solving this on a later day.
