The temps are pretty much OK. If it's stable in a benchmark, then it will be OK in a normal scenario. Nothing wll happen if you keep the OC, but don't try going any further though, you are already on the edge of the limit.
Its around 20°C over the Intel Recommended. It probably won't cause any problems,but it's safer to lower the clock speed till it gets to around 75°C
it was at the very high btw, idk if it mean a diffrence?
Its at full load, so in gaming it means it should be around 70°C, which is still high for a Skylake cpu. There are few CPUs that will be okay at that temp. (Mainly Intel Extreme and the AMD FX 9XXX Series)
when i am playing it is never even above 60, so idk
