I'm gonna give a lot of info on what I did and what I saw - please answer as many questions as you can and give advice if you know about the subject ...
Tried to OC my 1.3 GHz Athlon and MX400....
-Bought a new CPU cooling fan (cilindar with two fans on each end), I put a fan on my MX400 and added a fan (didn't have one but on Power Supply) for Case ...
- Few nights ago without any fans I ran 3D Mark @CPU @ 1430 (110FSBx13), but it rebooted twice after - so I went down to 103FSB till I get new fans in, for this test I left went to 105FSB ...
- I also bumped MX400 from 200(doubt that is right - prob +25 MGHz to real speed) to 215 Core and Memory from 166 to 200 MHz
- Ran 3D Mark 2001 - left my Comp - came back - it was OFF and could not be turned ON !!!!!!!!!!!!!!!!!!!!
- First thought was CPU burned (I know my temps were with old cooling 45C/46C runing, with new it seems it was going to 50 but that was at 105FSB
- Second was Mobo - guess what it was ....... ?
- Power Supply - 400W (didn't even know they make them like that - back in my tme there were 200 or 250W ...) - is it temp ? is it added fans (extre 3 fans)???
and not all - MY HARD DRIVE ?!?!?! WHY ????
40GB Maxtor pooped out ... so trip to MicroComputer Center cost $150 for 40 GB Maxtor (at lest now I have 7200 RPM)and $50 for Power Supply (350W - all 400W ones are $100 a pop !)
I don't dare hook all fans now (no extra for CPU no fan for MX400 - will watch temps and report ...
- Last but not least - low 50s in Celzius are ok CPU temps ?(both BIOS and Mobo Monitor report same ...) ?
Thanks all - shoot away !
P.S. Maxtor gives 3 year manufacturers warranty - right ? How bout Power Supply - anybody ever got one replaced ? Do they have fuse inside ???
