Okay so I need advice on a PSU
Toadex
Okay so I need advice on a PSU. Currently running
CPU: AMD FX-8350 Black Edition Vishera 8-Core 4.0GHz (4.2GHz Turbo) Socket AM3+ 125W
GPU: XFX Double Dissipation Radeon R9 290X R9-290X-EDFD 4GB 512-Bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video ...
MB: MSI 970A-G43 AM3+ AMD 970 + SB950 6 x SATA 6Gb/s ports
PSU: AZZA Dynamo 850 850W ATX & EPS 12V 2.91 SLI Ready CrossFire Ready Power Supply
That's all i need really to post about the build for right now. Now my Power Supply is crap... So i'm wondering what would be a viable replacement for the PSU? I'm past the point of being able to return it for replacement or refund so I need a new PSU.
I was thinking: http://www.newegg.com/Product/Product.aspx?Item=N82E16817104174
but not sure if that would work. Any other suggestions?
I looked into this one and it seems great. Just need one that I know I won't have an issue with (which i know you can't predict from the getgo). Had a PM that said this was an excellent choice, can only get the 650W on Newegg right now but that should be plenty. I wanna see what some other people say before I make a final choice.
Looking at the Power Supply Tier List (http://www.tomshardware.com/forum/id-2547993/psu-tier-list.html), FSP Aurum appears to be rated as a Tier 1 PSU.
I recently put together an Intel build with the same GPU you have on a 650W PSU (http://www.newegg.com/Product/Product.aspx?Item=N82E16817207034). I think 650W is sufficient for those who don't plan to OC or Crossfire.
