Hello, I decided to watercool a MSI 2070 super ventus with an old Corsair H75 AIO I had married to a kraken G12 bracket. Installation went fine. The problem is two fold. Possibly three. First, coolers that fit that G12 bracket are hard to find so finding a replacement is almost impossible. I've had that aio for 8 years and pump still works I think. Second, the temps are higher than the stock cooling and the H75 is making gurgling and metallic ticking sounds that sound like coming from the radiator. Could it just be bubbles and low fluid? Third, since the pump is upside down since on a GPU, radiator is above with tubing at the bottom of the radiator as it's supposed to be, could be a problem? Also can the aio be serviced if need be because like I mentioned before, finding a 120mm asetek style as I understand it, replacement is extremely difficult.
