Hello Minthe,
Just a bit of FYI to understand the issues with 32-bit and 64-bit OS upgrades and later options that may or may not be available to you later:
When upgrading from Windows Vista to Windows 7 you must upgrade the version currently installed within Windows Vista to the corresponding version in Windows 7. I.E. Windows Vista Home Premium to Windows 7 Home Premium; Windows Vista Business to Windows 7 Professional; and Windows Vista Ultimate to Windows 7 Ultimate. You also cannot upgrade a 32-bit operating system to 64-bit -- to migrate from 32-bit to 64-bit will require a custom install.
Additionally, you will not be able to "upgrade" from a 32-bit version of Windows 7 to 64-bit -- the architecture between the two is too drastically different to allow such a change. To learn more about the differences between a 32-bit operating system and 64-bit please go to the following link:
http://bit.ly/2aT3xP
Also check the Windows 7 Compatibility site: (There you will find out about hardware and software compatibilty.)
http://www.microsoft.com/windows/compatibility/en-us/default.aspx
There is a pulldown from which you can choose "hardware" and "software".
I hope that helps you out!
You can also find lots of information on Windows 7 here in our Springboard website:
http://technet.microsoft.com/en-us/windows/default.aspx
Thanks again,
John M.
Microsoft Windows Client Support
