Older Cooler Master Power Supply Out Of Date?
DevinC
100
Basically I'm wondering if I need to get another power supply for my new build or if I can salvage my old psu? It's a few years old and I feel like 1000w is going to be a bit overkill, but it certainly was overkill in my old build so I figured I'd bring it up.
Cooler Master Real Power Pro1000
I'm not sure if you need a lot of specifics to judge what should be used, but I'm wondering if you could either give me a wattage recommendation or suggested brand? I don't have a ton of brand loyalty and honestly don't know a ton about the ins and outs of power supplies.
I'll be working with either of these cpus i7 4770K or i7 4820K running on either a Z87-Deluxe board or Z79 Sabertooth TUF.
Starting with 8gig G.Skill RipJaws x2
ASUS Radeon HD 7950 x1
SSD with some back up drives, fans(no liquid cooling), and the rest of the standard build stuff.
This is with the intention of overclocking.
I'd say reuse. I've not used this particular model, but I Googled and your PSU looks pretty good to me. Reviews here, for example:
http://www.overclock3d.net/reviews/power_supply/coolermaster_real_power_pro_m1000_1000w_modular_psu/5
"The Coolermaster Real Power Pro M1000 is an extremely well rounded unit "
Editor's Choice award
http://www.hardwaresecrets.com/article/Cooler-Master-Real-Power-Pro-850-W-Power-Supply-Review/538/10
"We were really impressed with this power supply"
Silver Award
http://www.tweaktown.com/reviews/1163/cooler_master_real_power_pro_m1000_psu/index4.html
"An outstanding choice"
95%
On what basis? The PSU is made by a company called Enhance (and resold by Coolermaster) who I have honestly never heard of. Do Enhance PSUs have particularly poor failure rates? Can you provide figures/evidence to back this up?
Unless you can provide good evidence otherwise, I'd tend to side with the multiple professional reviewers testing with professional grade equipment, who all give this range of PSUs top marks.
One reason being, I want my new build tobe as up to date as ppossible. And the second reason being, I would have to buy another power supply for the old build if I would want to sell or use for some reason.
Ok...that Psu is up to date. If you want to buy another Psu, then plan on buying one for the system you are moving from. If you have 4 PCI-e 8/6+2/6 pin connectors I'd say you are just fine for this generation of parts. Save the money, and buy yourself a 500w or 550w Psu for you old system, and reuse the 1000w for your new system. It's a good quality Psu and will give you no problems in a brand new build.
