Hi. Everyone. This is the first time I will ever build a gaming PC and would like to know if everything I have is compatiable and if it work well together.
I want to play stuff like The Witcher 3, Gauntlet, and later games like FFXV i.e. basically multiplats that the Xbox One and PS4 will get in the future. I will be abandoning those systems. I want to be a PC gamer with a Wii U, 3DS and NX. I am fine with 1080p and 60 fps.
Does this build look good: http://pcpartpicker.com/list/8JKYcc
I am planning to get the GeForce GTX 1070 graphics card.
Also is my tower ok? Which would you recommend between these two and why:
http://www.amazon.com/Fractal-Design-Define-Gaming-FDCADEFR5WT/dp/B00Q380IOG/ref=sr_1_3?ie=UTF8&qid=1465175687&sr=8-3&keywords=fractal+white
http://www.amazon.com/Fractal-Design-Define-Gaming-FDCADEFR5WTW/dp/B00Q3BDMVE/ref=sr_1_1?ie=UTF8&qid=1465175687&sr=8-1&keywords=fractal+white
Thank you. I apprecaite any feedback or help since I am a novice
