Question Onboard Audio Issues
Sep 26, 2019
My microphone jack on both both the front and back panels emits a loud static pitch and lowers my voice to a point where it can't be heard. I have tried it with multiple different mics and have had no luck. I was wondering whether buying a cheap 3.5mm to USB converter off amazon would be the go, or whether a dac would be more helpful for my situation.
PS, voice is completely inaudible when on default mic settings, it can only be heard slightly when at 30+DB boost.
Hopefully I can find some guidance here. Cheers.
Motherboard is a msi b450 tomahawk.
