Question Ongoing Connection Issues - Wired/Wireless
NiveusT
60
I have Spectrum, 1G Download/60G Upload or something like that. Unlimited data, no caps.
The coax goes into the wall to a Netgear C7800 on one side of the house.
I have a Netgear WAX206 set up as an access point on the other side of the house. This is connected with an ethernet run outside, then under the house and up into a wall to a faceplate, from there, I connect the ethernet from the faceplate into the WAX206. Then I have my computer connected to that with an ethernet cord.
This worked amazingly for approximately 11 months. No hiccups, no problems.
(There are NOW, 5 things on the 5ghz band, and 7 things on the 2.4ghz band. And 3 things connected through cords/wired/physical connections).
Here comes the problems: My internet cuts out every 20 minutes-30 minutes or so for 20 seconds. On a wired connection. And it disconnects me from everything I'm doing. It's incredibly frustrating. Everything was fine until now. I do believe that during these small outtages my phone internet also cuts out. I need to pay closer attention to it.
The only thing different, unsure if relevant: My brother just set up some ring cameras around the outside of the house. And they're all connected to the wireless through the 2.4ghz channel. As far as I know, 3 of them are only in range of the main router/modem C7800. Only 1 is connected to the WAX206. I do not know how this is all set up, so I'm not sure if he changed some settings or something. He acts like me asking literally anything about this is a HUGE problem, so he won't answer me regarding the setup and since the internet from the C7800 seems to be fine and not spotty (he won't even answer me if it's fine on his end). I'm stuck dealing with this alone.
Solutions I have Tried:
Checked the coax was connected to the C7800. Restarted the C7800. Restarted the WAX206.
Updating Firmware (all up to date).
Called the internet company. They say there are no spotty connections or short drops on their end and they "ran a recalibration from there end". Still happens. They DO say that our modem/router isn't holding the connection well though?
Ran CCleaner and fixed registry issues (if it's just my computer). And Malwarebytes.
Ideas: Could it be the Ring cameras pinging the WAX206 or something to make sure they're connected and the ping is somehow messing with the internet?
I thought it might be the cord outside is having issues, but I am assuming this would cause way more problems than 20 second outtages every 30 minutes on a wired connection... Right? Like a rat biting into the line a tiny tiny bit wouldn't cause this? (The lines look fine outside though just curious if the integrity of the wire could be the issue).
Question: What are some things that I can do to diagnose this issue?
Is your home network similar to the following line diagram?
ISP === (coax, DSL, fiber) ===> Modem ---->[WAN Port] Router [LAN Port] ----> [LAN Port] WAX206 Wifi Access Point ~~~~> Wireless network devices (Ring Cameras) and one WAX206 LAN port to a wired Ring camera.
With other Router LAN ports -----> Wired network devices.
Feel free to edit and correct my line diagram as nececessary.
Or better yet, create your own network diagram showing all devices, connections, IP addresses and MACs.
Does not need to be a work of art. Just simple and clear enough that the whole of the network can be seen and understood.
You can scan or photograph the diagram and post the image here via imgur (www.imgur.com).
Who has full admin access rights to the router?
The starting point being to identify all network devices by IP address (Static or DHCP) and MAC.
The router's admin menus may help identify network devices both connected and disconnected plus any Static IP addresses that were configured. The Access Point should have a static IP address outside of the allowed DHCIP IP address range.
There should be no duplicate IP addresses with respect to wired or wireless connected network devices.
The 20-30 minute interval could be some data upload to Ring.
E.g.:
https://ring.com/support/articles/rul14/Downloading-and-Sharing-Your-Ring-Videos
Visit Ring's website yourself and learn more about the cameras and applicable network configurations.
More needs to be known.
Try to simplify things.
If a ethernet connection is also being affected it is not going to be a wifi problem.
So what I would first try is remove the AP and plug your pc directly into the connection going to the main router. This will eliminate the ap and a couple of the patch cables from being the cause.
If it is only 20secs you are going to have to be quick. What you want to do is do IPCONFIG /all and look at the status of the ethernet port. Mostly it would be if it is going to a disconnected state. This likely would be a issue with the long ethernet cable you ran.
If this is fine it gets a bit harder to find.
What I would now do is open 2 cmd windows. Leave a constant ping to the router IP and to a common IP like 8.8.8.8.
If you see loss in both when you think the internet is down it is likely some issue with the router....you kinda rule out the pc since you say many devices are affected. Check the logs in the router.
If the ping to the router IP works but 8.8.8.8 does not your internet connection is likely actually going down. Again see if the logs say anything. In particular you want to look at the modem part of the logs is you can.
Now if both work then it is a mystery. Most likely it is DNS but it could also be IPv6 going down but not IPv4.
I would first try to disable IPv6 in your pc and see if you still get the failure. Then try to manually set the DNS in the IPv4 settings to 8.8.8.8.
Problem is it is hard to make similar changes in phones and cameras. You should be able to disable IPv6 support in the router...you should not need it.
The default way DNS works is for the router to act as a proxy to the ISP DNS. Both the proxy function and the ISP DNS tend to cause issues. Best if your router has the ability to send the DNS in the DHCP setting to the end device. This way you can force your router to tell end devices to use say 8.8.8.8.
Note browser makers also have the ability to overridge the DNS in the browser settings making this problem even more confusing...ping and dnslookup work fine be the browser doesn't
E.g.:
View: https://imgur.com/a/oITxHLe
- < Network Structure.
I have full admin rights, all of us can, at any time, change anything.
All items have been identified.
I see in the event log of the Router that it says this:
2024-06-09, 20:04:38​
Critical (3)​
Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=6c:cd:d6:86;CMTS-MAC=00:01:5c:a;CM-QOS=1.1;CM-VER=3.1;​
2024-06-09, 00:57:27​
Notice (6)​
CM-STATUS message sent. Event Type Code: 24; Chan ID: 1; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=6c:cd::;CMTS-MAC=00:01:5:;CM-QOS=1.1;CM-VER=3.1;​
2024-06-09, 00:57:02​
Notice (6)​
CM-STATUS message sent. Event Type Code: 16; Chan ID: 1; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=6c:cd:d6:;CMTS-MAC=00:01:5c:a6;CM-QOS=1.1;CM-VER=3.1;​
I have deleted some of the mac address just in case (though I have no idea about how this works). This seems to happen around the time where the cutouts happen. I also noticed it doesn't happen at night for some reason. Just during the day... That's the mac address of our C7800 main modem/router that the coax goes into. (Unsure what the 00:01 mac is though, it's not any of our devices).
Could this be the problem? And what does it even mean?
Regarding the other questions- Should I change the ap to having the static then? I will have to look into this.
I do not know what the DHCIP IP Address Range is though, what does this mean?
No duplicate IP addresses were found on the list (that I can see).
(I see your message as well, Bill, thank you! If the above error I noted in the event log of the router is not the issue, I will try the steps you suggested, though it might be a moment since my family needs the internet, so fiddling with the access point when everyone's on wifi and other things might have to happen late at night or something lol - The 20 second outtage doesn't bug them, just me :<
I also checked the other logs and we're getting this:
[LAN access from remote] from 35.196.73.118:40366 to 192.168.0.88:25565, Sun, Jun 09, 2024 13:41:30
[admin login] from source 192.168.0.88, Sun, Jun 09, 2024 13:40:21
[DoS attack: Sync flood] from source: 159.192.106.207, port 50192, Sun, Jun 09, 2024 13:19:34
[DoS attack: Sync flood] from source: 159.192.106.207, port 31020, Sun, Jun 09, 2024 13:08:35
[admin login] from source 192.168.0.88, Sun, Jun 09, 2024 13:07:53
[DoS attack: Echo char gen] from source: 205.210.31.160, port 11175, Sun, Jun 09, 2024 12:49:28
[LAN access from remote] from 34.45.74.236:52464 to 192.168.0.88:25565, Sun, Jun 09, 2024 11:25:42
[LAN access from remote] from 13.64.193.54:54294 to 192.168.0.88:25565, Sun, Jun 09, 2024 10:57:28
[DoS attack: UDP Scan] from source: 221.11.5.53, port 37547, Sun, Jun 09, 2024 10:44:57
[DHCP IP: (192.168.0.213)] to MAC address c2:e2:80:0c:b4:f0, Sun, Jun 09, 2024 10:35:21
[LAN access from remote] from 193.32.162.15:60274 to 192.168.0.88:25565, Sun, Jun 09, 2024 10:25:26
[DoS attack: UDP Scan] from source: 115.231.78.5, port 12843, Sun, Jun 09, 2024 09:33:51
[DoS attack: Echo char gen] from source: 194.180.49.72, port 43314, Sun, Jun 09, 2024 06:37:25
[DoS attack: Echo char gen] from source: 104.152.52.229, port 57755, Sun, Jun 09, 2024 05:56:29
[DoS attack: UDP Scan] from source: 104.152.52.229, port 57755, Sun, Jun 09, 2024 05:55:56
[DoS attack: Echo char gen] from source: 94.232.47.101, port 43139, Sun, Jun 09, 2024 04:54:23
No problem with deleting the mac addresses. Not really necessary but as long as you can associate any given network device with its' respective mac and IP address that will help.
Specifically to ensure that there are no unidentified devices joining your network and that there are no duplicate IP addresses or macs in the network. Some devices can and do have multiple macs.
You can ignore those DoS attacks. Those happen all of the time and the router knows (or should know) what to do. Which is basically ignore...
This modem/router?
https://www.netgear.com/home/wifi/modem-routers/c7800/
This access point?
https://www.netgear.com/business/wifi/access-points/wax206/
Verify that I found the applicable device links.
Strange that all was well for eleven months. And that was until the Ring Cams were installed correct?
Is your computer PC1 or PC2? I think PC2 - just need to confirm either way.
And only that PC is affected by the 20 second outages every 20-30 minutes - correct?
Two thoughts:
How does the main router connect to the Access Point?
I found the documentation:
https://www.downloads.netgear.com/files/GDC/WAX206/WAX206_IG_EN.pdf
Note: Was the access point changed to access point mode? Was the access point ever reset? Maybe when the cameras were installed...
Connection should be router LAN to access point WAN as I understand Step 1A.
On your diagram add the IP addresses for all network devices. Do the four (4) Ring camera's have static IP addresses that are outside of the DHCP IP address range allowed to the router?
Double check the subnet masks - likely all are or should be 255.255.255.0. Post accordingly if not.
Are you able to use a browser and directly log into the WAX206 admin menus via the applicable IP address, login, and password? Any logs there? Enabled? (Trusting that the access point has a static IP addresse).
Have not worked out anything that directly or indirectly addresses the outage time pattern. And no outages at night..... Think about what could be different at night.
Could be some device trying to update, backup, or just phone home....
When you have the applicable quiet time I would proceed as posted by @bill001g and disconnect network devices. Starting with the access point.
If the problem ends then reconnect the access point and start disconnecting wireless devices one at a time. I would start with the Ring cameras and the Ring camera "associated" with the access point.
One more thing: When it comes to IP addresses you do not need to concerned about revealing private IP addresses.
FYI:
https://www.lifewire.com/what-is-a-private-ip-address-2625970
Knowing the IP addresses is very helpful for troubleshooting.
What you do not want to reveal is the address assigned by your ISP.
My home network uses a Linksys router and the 192.168.1.1 address.
If you run "ipconfig /all" (without quotes) via the Command Prompt on your computer you can obtain the router's IP address and the IP address currently provided to your computer.
And the router may have a listing of devices that are or have been connected to the network.
This modem/router?
This access point?
Two thoughts:
FYI:
That is the correct modem/router.
That is the correct access point.
That was until the Ring was installed. However- I do not know if the issue is directly related. I will be stopping their access to the network and see if the issue persists.
I have verified that it is not the WAX206. It's the main router causing problems.
My computer is PC2, but I have access to PC1 as needed if needed. I also have hooked PC2 directly to C7800. The issue persists.
The access point is in access point mode yes. I have checked all the logs for it and there are no errors with that one. It would seem all issues are with the C7800.
I will keep that in mind regarding the IPs. Thank you for the info.
The internet has cut out 6 times tonight, and these are the event log for the C7800.
2024-06-10, 08:35:06​
Notice (6)​
CM-STATUS message sent. Event Type Code: 24; Chan ID: 1; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2.;CM-MAC=6c:cd:d6:86:f5:84;CMTS-MAC=00:01:5c:a6:88:53;CM-QOS=1.1;CM-VER=3.1;​
2024-06-10, 08:34:45​
Notice (6)​
CM-STATUS message sent. Event Type Code: 23; Chan ID: 1; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=6c:cd:d6:86:f5:84;CMTS-MAC=00:01:5c:a6:88:53;CM-QOS=1.1;CM-VER=3.1;​
Notice (6)​
CM-STATUS message sent. Event Type Code: 22; Chan ID: 1; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=6c:cd:d6:86:f5:84;CMTS-MAC=00:01:5c:a6:88:53;CM-QOS=1.1;CM-VER=3.1;​
Notice (6)​
CM-STATUS message sent. Event Type Code: 4; Chan ID: 1 2 3 4 5 6 7 8 9 10 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 32 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=6c:cd:d6:86:f5:84;CMTS-MAC=00:01:5c:a6:88:53;CM-QOS=1.1;​
2024-06-10, 08:34:44​
Notice (6)​
2024-06-10, 08:34:33​
Notice (6)​
CM-STATUS message sent. Event Type Code: 5; Chan ID: 1 2 3 4 5 6 7 8 9 10 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 32 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=6c:cd:d6:86:f5:84;CMTS-MAC=00:01:5c:a6:88:53;CM-QOS=1.1;​
2024-06-10, 08:34:22​
Critical (3)​
No Ranging Response received - T3 time-out;CM-MAC=6c:cd:d6:86:f5:84;CMTS-MAC=00:01:5c:a6:88:53;CM-QOS=1.1;CM-VER=3.1;​
2024-06-10, 08:33:58​
Critical (3)​
SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=6c:cd:d6:86:f5:84;CMTS-MAC=00:01:5c:a6:88:53;CM-QOS=1.1;CM-VER=3.1;​
Warning (5)​
MDD message timeout;CM-MAC=6c:cd:d6:86:f5:84;CMTS-MAC=00:01:5c:a6:88:53;CM-QOS=1.1;CM-VER=3.1;​
2024-06-10, 08:33:57​
Critical (3)​
If more info is needed, I can do my best to give more. Any further ideas, I will try. First thing I will try to disconnect the ring cameras.
Could it possibly just be our router is dying? It's about 3.5 years old or so.
If the router was dying I would expect to see more problems affecting more devices....
However there is merit in taking a closer look at the router.
I "looked up" that 6c:cd:d6:86:f5:84 Mac address. Netgear.
Reference:
https://macvendors.com/
Overall the router is becoming more and more suspect.
I will defer to others regarding the scope of the errors being presented by the router. Certainly a clue but I would be looking for an error pattern that matches the observed 20-30 minute timing.
For more about router errors, etc.
https://community.netgear.com/t5/Ca...ble-diagnostics-on-the-Nighthawk/td-p/2378543
Look for entries that are not as you would expect or otherwise do not match the specs.
I would also take a close look at the coax cables serving the router. Inspect all cables (do so safely - no climbing on roofs, poles, etc.) for signs of damage, corrosion, water, etc., Ensure that all unterminated cables are properly capped with real terminators. Not dust caps.
https://blog.solidsignal.com/tutorials/tip-terminate-unused-ports/
Coax splitters are cheaply made and can (and do) degrade with age. Check them as well. Sometimes problems are solved by simply disconnecting and reconnection the cables.
Continue trying to narrow things down. Could be multiple problems....
At some point, if possible, it may simply come down to swapping in another known working router. Do you own or rent the C7800? I think own but want to be sure.
We had some techs come out and double check all the cables and coax and things. The ISP checked the pole and said something was wrong with the pole and they'd get someone out to check the pole. However- I do not trust the ISP to know if that's the final issue. Here are the errors that show up with the connection on the router. These errors happened around the time the internet cut out about 20 times every 3 minutes for 20-30 seconds. All splitters/lines from the house to the pole and from the house to the router/modem are all fine according to the 2 ISP techs that came out 🙁 We own the C7800. Sorry for the slow replies. Lots of unrelated random stuff happening in life atm.
2024-07-11, 17:41:04​
Notice (6)​
CM-STATUS message sent. Event Type Code: 5; Chan ID: 1; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=6c:cd:d6:86:f5:84;CMTS-MAC=00:01:5c:a6:88:53;CM-QOS=1.1;CM-VER=3.1;​
2024-07-11, 17:40:48​
Notice (6)​
DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2.;CM-MAC=6c:cd:d6:86:f5:84;CMTS-MAC=00:01:5c:a6:88:53;CM-QOS=1.1;CM-VER=3.1;​
2024-07-11, 17:40:47​
Notice (6)​
TLV-11 - unrecognized OID;CM-MAC=6c:cd:d6:86:f5:84;CMTS-MAC=00:01:5c:a6:88:53;CM-QOS=1.1;CM-VER=3.1;​
Error (4)​
Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=6c:cd:d6:86:f5:84;CMTS-MAC=00:01:5c:a6:88:53;CM-QOS=1.1;CM-VER=3.1;​
Error (4)​
Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=6c:cd:d6:86:f5:84;CMTS-MAC=00:01:5c:a6:88:53;CM-QOS=1.1;CM-VER=3.1;​
Warning (5)​
DHCP WARNING - Non-critical field invalid in response ;CM-MAC=6c:cd:d6:86:f5:84;CMTS-MAC=00:01:5c:a6:88:53;CM-QOS=1.1;CM-VER=3.1;​
Time Not Established​
Notice (6)​
Honoring MDD; IP provisioning mode = IPv4​
Critical (3)​
It looks like your ISP has not provisioned the router properly, or one of their drops isn't configured properly.
Have you tried saving the config on the router, resetting to factory defaults, and seeing if it works by default? If it does then your config is doing something wrong.
Find the device with the MAC shown in the log.
This is my router's mac address.
I had 3 techs come out, adjust things on their wires etc. And still the issue persists. How can I tell them that it's the provisioning of the router in a way that will get them to check these things? They always just want to send out a tech with whatever I say lol...
I will have to try the config of the router you mentioned- Though... We haven't really changed much on it besides adding the wi-fi.
Is it unlikely to be the Access point if no error logs or anything are showing up on the access point itself or on the router in relation to the access point's mac?
Side Question: If it was a hardwire ethernet CAT cable going bad or something- It would be much more of a problem than just periodically disconnecting for 20 seconds right?
The other device MAC that shows up is "CMTS-MAC=00:01:5c:a6:88:53;CM-QOS=1.1;"
[My bold].
What I am trying to discover are possible configuration errors. By matching errors to listed macs.
For example using one of the log errors I found:
https://themescene.tv/guide/missing... 1 1.,server ... 7 7. Seek technical support
And I find links such as this one:
https://superuser.com/questions/161...vity-problems-captured-log-what-do-these-erro
Take some time to google the various errors. See what you can find and learn.
No need to take immediate action - post first so everyone can have an opportunity to check what you come up with. You will find registry edits, third party software, misc. online hacks etc.. May or may not be applicable and should be avoided until there is some certainty that what is found is indeed the culprit.
And you can scroll through the routers's logs for the most common errors and other errors that may be listed.
You may read or see something that is a "Eureka" moment.
I had a semi eureka moment...
I think it's my access point (the WAX206).
I connected directly to the MAIN router with my PC, and I had no problems at all. (I know I should have done this sooner but everyone is always using it so I stayed up late one night to check.)
I plugged it back into the WAX206 (Set as an AP), and it started intermittently cutting out, but I couldn't figure out what the problem was. The logs say nothing for the WAX206. I also see nothing regarding it in the main router (Netgear C7800)'s logs.
I cannot tell what is causing these cut outs. Nothing specific happens at the time of these disconnects, but once they start... It's REAL bad.
I've FACTORY reset my WAX206. It seems like it's mostly better, but there are tiny little hiccups every 2 minutes for about 1 second on some games.
Is there a way to monitor my connection constantly to see the exact times so I can start checking things? The disconnects are/were so short that sometimes they were un-noticable unless I'm playing a game that gives connection info.
This:
"Is there a way to monitor my connection constantly to see the exact times so I can start checking things? The disconnects are/were so short that sometimes they were un-noticable unless I'm playing a game that gives connection info."
I believe that you should take another look at @bill001g 's suggestions in Post #3.
However, I will otherwise defer to any additional thoughts or related suggestions he may post based on the interim posts.
So, I'm fairly certain it's the AP at this point.
I did the ipconfig /all during the drop outs. Everything shows up fine and not disconnected.
Ipv6 was already disabled from my PC apparently from the start.
I did the constant ping to 8.8.8.8 with cmd prompt "ping -t 8.8.8.8" - There are no drops in connection, HOWEVER, I did notice that there are random tiny mini lag spikes where it goes from ms=8-10 to around ms=28 or so, and in hindsight that's not a large problem, but I think there's packet loss or something as well that makes it so things cut out completely for a moment constantly every few minutes. At the same time it did this ms=28, I did ipconfig /all. It did not disconnect my ethernet.
The logs in the router do not say anything during these spikes, unfortunately. Neither for the wax206 or the c7800.
I am unsure how to do the DNS ipv4 to 8.8.8.8- Once I do that, what happens with this? Do I just leave it as that forever? I also am unsure about that last paragraph 🙁 I"m not sure how that would work on my wax206 since that seems to be the problem. I do not see the option anywhere in the settings themselves on any of the menus.
If I need to buy a new access point and not the wax206.. (It's about a year old now)... Is there a good residential one that works well with netgear? =\
Thank you guys for the help very much thus far 🙁 I hate networking problems lol
10-20ms spikes are not going to be detectable in normal usage. You only see it because you are testing for it. Even 100-200ms is hard to tell except in online games where you would see a lag spike. Most other stuff uses buffers and will hide it from you. You would need a spike of a couple seconds to cause a session drop in most cases. Online games are a bit more sensitive and even a full second can cause the server to boot you.
On my pc I always leave 8.8.8.8 or sometime 1.1.1.1 permanently hard coded. I also use the somewhat new feature that lets me also use encrypted DNS. I am not sure how you set that option other than using the hardcode method.
DHCP is not run on your AP it should only run on your main router. If you have multiple DHCP server function running you can get all kinds of strange issues.
The exact details of what you can set on a router DHCP settings vary quite a bit. Almost all allow you to put a hard coded DNS server in the DHCP setting page. This will cause the router to give end device the DNS you key in rather than the default which is to give the device the IP of the router.
Although it might not matter to you I am not sure how you set the new encrypted DNS options via a DHCP server. I assume it is some new optional subcode that is sent but I never bothered to look up the details. I know the router I have do not have the option.... then again I have not updated my firmware in quite a while.
Yeah, I only noticed it because in the games I play (CS2, and Rainbow6 Siege, and a bit of Valorant) in the corners of the screen it will say "packet loss" or "connection problems" and show a download/upload red number that tells you what's happening, and I get super rubber banding. But it's on everything I play, even in normal discord calls.
During the times this shows up, I look at my CMD prompt and at those moments the MS goes up temporarily. And that's the only thing I see from Bills suggestions.
Where do I go to try this 8.8.8.8? I'm sorry. I've not had to adjust things like this in a long time.
Out of curiosity, is it possible that the access point is degrading or having hiccups in general? If so you have a recommendation on a replacement access point?
So currently, just to make sure I understand, the things I will be trying are setting my PC to DNS 8.8.8.8 and/or to try putting it as default DNS for my router at 8.8.8.8
UPDATE****: When it cuts out for a second it says "Request timed out" on the ping -t 8.8.8.8. The ipconfig /all says everything is connected even when it times out. I also ran a ping -t to the 192.168.0.1 router, and it does "request timed out" on that as well. I think that means the connection gets timed out on pinging my router as well? At some points it goes to "general failure" and it cuts out completely. This is only happening when getting internet through the WAX206 access point.
UPDATE #2***: While keeping on the cmd prompt pinging. I noticed that it's not cutting out at all while I'm not playing any games... The second I start trying to play games, it cuts out a lot. (In the ping 8.8.8.8 and 192.168.0.1 - it "Request Timed Out" or "General Failure"d often when gaming, but otherwise not at all. Even when streaming videos. )
What does this mean? I do not see any pattern to it.
Do you have the ability to run a wired connection all the way to the router. The WAX206 is a strange for a AP it looks much more like a router which is good in this case. Most true AP only have 1 ethernet port and can be powered by POE but the wax206 does not.
In any case can you run a second cable from the WAX206 to your PC. This way it will be ethernet from the main router to the AP and also ethernet from the AP to the PC.
The reason for this question is you need to find out if there is a issue between the router and the AP or if it is the more common wifi issue. When you get failure to 192.168.0.1 it means the problem is local to your house. Testing with ethernet would eliminate the cabling, the AP hardware and everything in your pc other than the wifi nic.
Wifi problems are made even more complex when you are using AP. Are you 100% sure your pc is connecting to the AP and not the main router or maybe a different AP in your house. Can you be sure which radio you connect to...ie 2.4 or 5.
Although having the SSID for the wifi the same makes thing easier in some ways it makes troubleshooting harder. Having different SSID even just to test make it much easier to know exactly what chips and hardware you are using.
With wifi problems are mostly related to the signal levels and the amount of interference you are getting. It is the standard try to move the pc a bit in the room to see if something is blocking the signal. Try to use 2.4 or 5 and see if one is better than the other.....Note games do not need high bandwidth so even if it would have lower speedtest numbers it might have less packet loss.
In the end it is extremely common to get random data loss and lag spikes when you attempt to play online games on wifi. Can be interference from things inside and outside your house.
Note what you are describing now is different than the internet going down for 20 seconds. If it still does that maybe the AP is rebooting because of some hardware failure
All of this is happening on a wired connection thru the WAX206. Internet > Router (C7800) > AP (WAX206) > PC - All wired. This is when there are problems. The PC is my main concern because it's the one I game on as well as do zoom calls/meetings/etc on (wired). The wireless devices/wi-fi isn't a concern really for this issue, cause all the things people do on the wireless in this house is pretty much just web browsing, so the hiccups aren't a big deal really (except for the wired connection to my PC).
Internet > Router (C7800) > PC - All wired (same wire runs). There are no problems. The AP seems to be having a hiccup between the Router > AP > PC - When I run a ping -t 192.168.0.1 to the router, it will get "Request Timed Out" or "General Failure" when these issues happen. Same with ping -t 8.8.8.8.
When it shows "General Failure" it disconnects me from the internet completely. This is when it goes down for 20 seconds that I was describing. The "Request Timed Outs" are causing huge lag spikes in the game that causes rubber banding. As well as frozen video. Etc.
Almost sounds the like AP is rebooting or something. General failure most times means the ethernet port went down at a physcial level but maybe the AP is just not passing traffic but electrially still on.
So if I understand. You have this.
Router---walljack---cable in wall--wall jack--cable to ap---AP-- cable to the pc.
If you plug the pc into the wall jack going to the router it works fine.
Can you try to use LAN ports for both connection to the AP. This AP is a bit strange maybe wan and lan ports are different somehow.
If I read this thread you have mulitple wax206 AP ?. What happens if you swap them around.
You might consider a small switch to connect everything that way if the AP fails it doesn't affect your pc.
Your diagram of my network is correct. Yeah, it works fine from wall jack to my PC.
I did try the WAN and LAN ports on the WAX206 and they both do the dropping 🙁
I only have one WAX206 AP. :<
Yeah! I actually just bought a switch today LOL... Ugh. I'm sad the AP isn't working as intended anymore. It just suddenly started 2-3 months ago or so.
UPDATE:
I will start semi-fresh and reiterate the problems, but just in case all of the above info is relevant I will leave it here.
My current setup:
ISP >COAX> Router/Modem Combo (Netgear Nighthawk C7800) >wire> GS305E – 5-Port Gigabit Ethernet Smart Managed Plus Switch >wire> Windows 11 PC
Every 2-5 minutes + there is a random lag spike that creates lag in games, videos, and otherwise.
Originally, before I swapped to this new Network Switch, I had it going through an access point to my PC. That access point would have "Requested Timed Out" and "General Failure" constantly in an 8.8.8.8 ping as well as a 192.168.0.1 ping in CMD Prompt. So I swapped it to a network switch and now have the wire going to my PC directly through that. The switch also goes to the access point which is not an issue for my hardwired PC that I need the constant good connection on. The wi-fi can break on that access point and I don't mind it. SO-
The network switch has gotten rid of the "request timed out" and "general failure" issue. However, now, as mentioned, there is a 2-5 minute random lag spike.
While I am playing games and doing other things, I have a constant CMD Prompt going with:
ping -t 8.8.8.8
ping -t 192.168.0.1
During these lag spikes, the there is no request timed out, and no general failure, but there is a noticeable increase in the MS of the ping to the 80-100 range for 8.8.8.8 AND an increase to about 40-70MS on the 192.168.0.1 ping.
1. The router event log says nothing at the time of these spikes.
2. The router security log says nothing at the time of these spikes.
3. No one else but me is awake at the time of these spikes.
4. IPv6 is disabled on my PC.
5. All network firmware is up to date.
6. ISP has come out 3 times, checked our wires to our house from the pole, our coax cables, and a bucket truck was taken around the area to check all connections and wires on poles. They only saw outtages coming from us for approximately 3 minutes ONCE in the day, and all of my small cut outs and higher lag spikes were not detected on their end, and they say it might be our router. (They showed me their laptop of all the diagnostics. Everything looked great on all neighbors, and everything else was constantly connected to us save for a 3 minute outtage but that doesn't explain the constant lag spikes).
My Plan: I bought a 100ft cat6 heavy duty cable from Amazon. When everyone is asleep, I will be running it directly from the router to my PC to see if there are any lag spikes. I have done this without the switch as well, it seems the connection is more stable, but it's also got a lot of ports to go through. (router to wall, wall to outside, outside to under house, under house to inside wall, inside wall to port, kinda thing). So I wanna do it just directly with one single wire no inbetween ports to see if one of them might be going bad.
Question: What are my next steps here? What else can I do to check things?
IF you recommend buying a new router, which of these is best in your opinion for a good home wi-fi/wired network for gamers who need a constant good connection? (Approved for up to 1G) If you're allowed to tell us this. Spectrum Approved Router/Modem List I'm open to all suggestions.
The key thing that stands out here in latest post is.
"During these lag spikes, the there is no request timed out, and no general failure, but there is a noticeable increase in the MS of the ping to the 80-100 range for 8.8.8.8 AND an increase to about 40-70MS on the 192.168.0.1 ping."
So the way ping works it builds a special packet and sends it to the router...in this case. The router takes the packet and basically reverses all fields and sends it back to the pc. The pc then calculates the amount of time that has passed between the 2 packets.
Your normal lan ping time is well under 1ms. Pretty much the only delays are related to cpu processing time. Very technically the cable causes a delay but we are talking speed of light things.
So you pretty much have 2 cpu that can be causing this. The router might have been busy when it received the packet and waited to send the response. The other would be the pc doing the ping was busy. This gets complex because the operating system itself might have gotten the packet but the process that was running the ping did not. Although very uncommon it could be a error in the driver code.
Although I don't know how much help it will be maybe boot a USB linux image. Let a ping run to the router IP overnight. Note the ping command is slightly different. If this has issue maybe suspecting the router would be valid.
Since it seems you have a fancy switch that most people don't maybe try to intercept the data between the pc and the router. I think the switch you have has port mirroring...not 100% sure the 105e does.
So hopefull you have a old pc you can use to capture data. You want to run wireshark on it and plug into the mirror port. I would build filter to capture just the ping packets. You should now actually see when the packets are really being sent in each direction and can see which device is causing the delays. If you get very lucky you might see something capturing general traffic. Watch for things like ARP when you see the delays. Could be some ipduplication.
Note before you go down this path be 100% sure you continue to see the delay to the router ping when you see actual problem. Lots of effort this is just some strange coincidence
If it comes down to that- I will do that. But out of curiosity, in all of these tests- If it is the router, basically it comes down to replacing the router possibly, or adjusting the settings somehow and see if it fixes, right?
If it is NOT the router... Is it likely to be a driver issue/firmware issue?
Just so I know what I'm getting into before I do all that stuff you're sayin? Since I only got the one PC I can do things like this with :/
