Question Ongoing issue with USB ports ?
Mar 29, 2024
15
Hi there,
I've had an ongoing issue with my usb ports for what must be 2 years now, and i've just kind of dealt with it but i'm curious as to whether theres a fix or not. So for a long while i've had this situation where my USB ports will sometimes randomly cut off, it could be one of them, could be both, sometimes ( though rarely ) its all of them, only ever happens for a few seconds, everything comes back and works fine. I've had no way to replicate the issue, i've gone months with it not happening, then sometimes it happens every day for a few days, i've replaced usb hubs, tried direct into the back of the pc, turned off all sorts of power saving and suspend settings, but nothings completely stopped it. Its less of an urgent issue and more of an annoyance when i'm mid game and my controller drops for a moment or two, or calling with friends and my mic cuts off for a second, anyone know the route cause?
GPU: Gigabyte GeForce RTX 4070 Super windforce OC
RAM: Corsair VENGEANCE RGB PRO SL 16GB (2x8GB) DDR4 3600 (PC4-28800) C18
PSU: NZXT C750 - NP-C750M-UK - 750 Watt PSU - 80+ Gold Certified
Motherboard: MSI B450 TOMAHAWK MAX Motherboard ATX
Boot drive ( SSD ): Samsung SSD 980 1TB
CPU: AMD Ryzen 7 5700X 8-Core Processor
Case: Fractal Meshify C
Hi there,
Did you update BIOS ? There was an issue with USB ports with early BIOS version.
I most recently updated it about a year ago roughly, i remember having the issue before i originally updated and its sort of followed since, its confusing cause i can go weeks upon weeks with zero issue, then it just happens suddenly, then back to normal
So i think i've jinxed myself by saying it didn't happen often because it seems to be happening with more and more frequency now. I was playing final fantasy XIV and kept getting these weird 1fps stutters coinciding with every usb hub turning off and resetting themselves, it doesn't matter if its plugged into the back of my pc, the ports at the front, or via a hub, i looked in event viewer but i'm very new to stuff like that so i had no clue what i was looking for, i had a couple of errors around the time it happened, one being devicesetupmanager event id 152, a bunch of disk warnings ID 51, Kernel-eventTracing event ID 28, and a few BTHUSB event ID 17. Very much been a constant head-scratcher
Hi there,
I've had an ongoing issue with my usb ports for what must be 2 years now,i'd made a post beforehand and it ended up fading for a while so i wasn't as in need of an answer, however its returned and happens at least once a day, if not more.i've just kind of dealt with it but i'm curious as to whether theres a fix or not. So for a long while i've had this situation where my USB ports will sometimes randomly cut off, it could be one of them, could be both, sometimes ( though rarely ) its all of them, only ever happens for a few seconds, everything comes back and works fine. I've had no way to replicate the issue, i've gone months with it not happening, then sometimes it happens every day for a few days, i've replaced usb hubs, tried direct into the back of the pc, turned off all sorts of power saving and suspend settings, but nothings completely stopped it. Its less of an urgent issue and more of an annoyance when i'm mid game and my controller drops for a moment or two, or calling with friends and my mic cuts off for a second, anyone know the route cause? i looked in event viewer but i'm very new to stuff like that so i had no clue what i was looking for, i had a couple of errors around the time it happened, one being devicesetupmanager event id 152, a bunch of disk warnings ID 51, Kernel-eventTracing event ID 28, and a few BTHUSB event ID 17. Very much been a constant head-scratcher, I invested in a usb hub that's powered separately but its still not solved the situation, any advice is appreciated!
Instead of Event Viewer (for now) look in Reliability History/Monitor.
Much more end user friendly and the timeline format may reveal patterns.
Plus you can click on any given entry for more details. The details may or may not be directly helpful.
Open Reliability History/Monitor. Expand the window so all can be viewed.
Select Day view as a starting point.
Then look for a day with many errors, etc.. Select that day.
Take a screenshot and post the screenshot here via imgur (www.imgur.com > New Post).
