I was looking at videos of fully-immersed systems in mineral oil and had a better idea. It would be to use the mineral oil only for the liquid-cooling radiator.
So essentially you'd have a water-cooling system but instead of having the radiator just open in the air making tons of noise, is it possible to ONLY immerse the radiator in the mineral oil leaving the rest of the system normal (not in mineral oil)?
EDIT: The fans will be attached to the radiator and will be rotating in the mineral oil.
