Optical better than non-optical?
G
Guest
Guest
Archived from groups: alt.comp.hardware,alt.comp.hardware.pc-homebuilt,uk.comp.homebuilt,alt.comp.hardware.homebuilt,microsoft.public.windowsxp.general (More info?)
"E2E t-bot BT" <English-to-English.translator.bot@Babel.Fish>
wrote:
> I am still using a corded mouse (logitech wheelmouse).
> I would like to get a better mouse which has at least as good
> precision, responsiveness, accuracy, etc.
> Would an optical mouse be better on all counts?
> What about a cordless mouse. Are they poor performers? What
> about a Bluetooth connection - is that good. Is it pricey.
> Are there any web sites which discuss this. Google is no help
> to me.
Assuming both are cord-attached then is an optical mouse is
inherently better than a non-optical mouse?
>> to me.
....like INFINITELY better. 😵
Onideus Mad Hatter
mhm ¹ x ¹
http://www.backwater-productions.net
The big difference is that an optical mouse has no roller ball, hence it
doesn't require a mouse pad, can be used on virtually any solid surface and
there are no maintenance problems such as grime clogging the roller ball
thus requiring it to periodically be cleaned.
Michael Solomon MS-MVP
Windows Shell/User
Backup is a PC User's Best Friend
DTS-L.Org: http://www.dts-l.org/
"Piotr Makley" <pmakley@mail.com> wrote in message
news:94C6EA6A6FDAA31E75@130.133.1.4...
>> to me.
I would prefer optical with a USB wire. I might have a
wireless as a second device.
I al;so like trackballs. The trackball does need to be
cleaned because dust, lint and even dead skin cells do get
in the ball socket. A standard optical mouse is
self-cleaning since the base is flat. They work on any
surface except polished metal and mirrors.
"Michael Solomon (MS-MVP Windows Shell/User)"
<user@#notme.com> wrote in message
news:%23GD7VHoHEHA.4088@TK2MSFTNGP10.phx.gbl...
ball, hence it
solid surface and
the roller ball
| Windows Shell/User
| > "E2E t-bot BT"
as good
What
pricey.
no help
| >> to me.
is
Way over-simplified. It depends on how you use it. If you are only running
office apps. on a desktop computer and have a decent (non-reflective) mouse
pad, then it's hard to beat an optical mouse. For a notebook, you want a
mechanical mouse (the kind with a mouse ball). That's because optical mice
don't work too well on many surfaces you will find in motel rooms, and it's
inconvenient to have to carry a mouse pad with a notebook computer. Also,
optical mice (all brands) get a bit jumpy on quick movement. If you are a
gamer, you might want to stick with the ball. -Dave
AFAIK, optical mice are at a disadvantage in only in two respects:
1. They draw about ten times the power of mechanical mice, which may
be why cordless versions are still rare.
2. They won't work on clear glass surfaces or on mirrors.
I've used only three brands of optical mice -- Logitech, Memorex, and
i-Concepts/Sakar, the latter two really cheap ones, all have worked
far better than any mechanical mouse I've tried. No more skipping or
stuck cursor if the surface was rough, dirty, or too slick or if the
mouse rollers accumulated lint. OfficeMax often features an optical
mouse for free after $10 rebate -- see www.salescircular.com, and
Fry's has had them for as little as $2.99, no rebate.
Optical mice work great on my blue jeans or my bare leg.
Haven't tried my gut.
"Dave C." <spammersdie@ahorribledeath.now> wrote in message
news:qsidnfEWSrvxrerdRVn-sw@comcast.com...
mouse is
computer. Also,
My uncle uses a trackball, it drives me nuts!<VBG> Whenever he asks me to
figure out some issue he's having that darn trackball just gets in the way.
In the future, I'm bringing my own mouse!
Windows Shell/User
"Jim Macklin" <p51mustang[threeX12]@xxxhotmail.calm> wrote in message
news:e4hyecoHEHA.3356@TK2MSFTNGP11.phx.gbl...
> ball, hence it
> solid surface and
> the roller ball
> | Windows Shell/User
> | > "E2E t-bot BT"
> as good
> What
> pricey.
> no help
> | >> to me.
> is
running
mouse
mice
it's
Definitely depends on how you're going to use it. I find that because the
mouse is so light the tension from the cord will actually make it spring
back when you let go. This is a problem when doing CAD work. I'm going to
try a mouse pad to see if that will give some more friction, but I think it
is a function of weight vs. tension. Otherwise I like the ease of use and
smoothness. A good reason to go wireless and optical, I guess. But I don't
like the idea of batteries.
Wireless Ones: What happens when they (batteries) get low? Do you get a
warning of some sort, or do funky thing start happening?
And I prefer IBM's TrackPoint pointing system to the touchpad found on most
laptops...That's my opinion, I'm sticking to it!🙂
Windows Shell/User
> ball, hence it
> solid surface and
> the roller ball
> | Windows Shell/User
> | > "E2E t-bot BT"
> as good
> What
> pricey.
> no help
> | >> to me.
> is
On 9 Apr 2004 19:30:49 -0700, larrymoencurly@my-deja.com (larrymoencurly) wrote:
Cordless optical mice are rare? Um...*checks the Staples website*...well you can choose between TEN
different models of cordless optical mice at Staples alone... 😵
Because so many desks are made out glass and mirrors...and for those times when you want to use the
mouse directly on the monitor, oh yeah, yer piss outta luck...but you know, white out on the monitor
will still work. ^_^
Onideus Mad Hatter
mhm ¹ x ¹
I use a MS Trackball Optical with the trackball under my
right thumb and I click with my index finger, scroll with
the middle and right click with the ring finger. A friend
has a MS Trackball Explorer with the buttons on the side and
the ball on top. That is always a hard switch to do.
news:%23SCFa6oHEHA.700@TK2MSFTNGP09.phx.gbl...
gets in the way.
| Windows Shell/User
in message
get
roller
| > ball, hence it
any
| > solid surface and
clogging
| > the roller ball
| > | Windows Shell/User
| > | > "E2E t-bot BT"
wheelmouse).
least
| > as good
performers?
| > What
| > pricey.
is
| > no help
| > | >> to me.
mouse
| > is
You might try a WACOM graphing tablet and pen for the CAD.
www.wacom.com
"BP" <Zpoweretal@110.neZt> wrote in message
news:107efld4pgkjv9c@corp.supernews.com...
message
mouse is
you are only
| running
(non-reflective)
| mouse
because optical
| mice
motel rooms, and
| it's
that because the
make it spring
work. I'm going to
ease of use and
guess. But I don't
Do you get a
On Fri, 9 Apr 2004 19:52:18 -0500, "Jim Macklin" <p51mustang[threeX12]@xxxhotmail.calm> wrote:
>www.wacom.com
Yeah, I was about to say, doing CAD work with anything other than a graphics tablet is just...not
much fun.
Onideus Mad Hatter
mhm ¹ x ¹
On Fri, 9 Apr 2004 18:31:16 -0500, "Jim Macklin" <p51mustang[threeX12]@xxxhotmail.calm> wrote:
Works fine on my stomach.... might be the hair giving it texture tho...
>mouse is
>computer. Also,
Bait for spammers:
root@localhost
postmaster@localhost
admin@localhost
abuse@localhost
postmaster@[127.0.0.1]
uce@ftc.gov
Remove "spamless" to email me.
A real computer geek would have the hair removed and get a
tattoo over an 6x6 area for the mouse laser to track.
"Overlord" <kurt_SPAMLESS@hotmail.com> wrote in message
news:40773ca1.577933593@news.central.cox.net...
texture tho...
message
| >mouse is
notebook
| >computer. Also,
| Bait for spammers:
| root@localhost
| admin@localhost
| abuse@localhost
| uce@ftc.gov
Depends to some extent on your desk. I used to play several hours
of UT at a time smoking cigs occasionally. Of course if I was chasing
someone or had my crosshairs on someone on a roof across town,
I wasn't paying too much attention to the cigarette. Got rid of a nice
Boomslang Razor with programmable buttons I could save key sequences
to that would work in the game(!) because it seemed I was always cleaning
the internals on the mouse. Now I use a Logitech optical mouse.
Very smooth, can't program keystrokes to the buttons but I'm also
not getting killed because I can't move.
>> to me.
Bait for spammers:
root@localhost
admin@localhost
abuse@localhost
uce@ftc.gov
running
mouse
it's
I disagree. there are a number of paper thin mousepads out there
specifically designed for Optical mice and quite nicely fit in between the
laptop screen and keyboard. However, anyone carrying a laptop will of course
have it in a laptop carrying case. A standard mouse mat let alone a paper
thin one will fit nicely in the side pocket.
>Also,
Again, I disagree. Aside from having normal hobbies and pursuits such as
climbing, abseiling and socialising, I am also an avid gamer and have tried
a number of mouse mats out. ALL gamers I know including myself ALL have
Optical mice and Paper thin or NO mouse mats.
My particular mouse mat is paper thin, made by a company called
Microthin.com and cost me $6 at Quakecon in Dallas last year. The Microthin
site seems to specialise in Advertising mouse pads.. don't ask.. mine is a
non advertising mouse mat. - called Microthin Headshot.
I won't use anything other than this. No jerky movements from my MS
Intellimouse Explorer 3 and smooth action all the time as the mouse mat is
teflon covered.
"Michael Solomon (MS-MVP Windows Shell/User)" <user@#notme.com> wrote in
message news:#GD7VHoHEHA.4088@TK2MSFTNGP10.phx.gbl...
> and there are no maintenance problems such as grime clogging the roller
> ball thus requiring it to periodically be cleaned.
Instead - particularly if you have pets - you occasionally get a hair in
front of the sensor, with much the same result.
Alex
Hmm, good point.
Windows Shell/User
"Alex Fraser" <me@privacy.net> wrote in message
news:c57e9m$2prukp$1@ID-149533.news.uni-berlin.de...
> Alex
Cats and dogs belong outside or at least in another room
from the computers.
news:uT33pUpHEHA.2128@TK2MSFTNGP11.phx.gbl...
| Hmm, good point.
| Windows Shell/User
any solid surface
clogging the roller
| > Alex
Well, that's good in theory!
Windows Shell/User
news:OFdiPfpHEHA.3696@TK2MSFTNGP10.phx.gbl...
> from the computers.
> | Hmm, good point.
> | Windows Shell/User
> any solid surface
> clogging the roller
> | > Alex
> in the ball socket.
AFAIK most dust found where people are /is/ dead skin cells :).
> A standard optical mouse is self-cleaning since the base is flat.
Neither of the two I have used - an Microsoft one and a Logitech one - have
a flat base.
> They work on any surface except polished metal and mirrors.
Anything really shiny seems to cause problems. I had a mouse mat where the
textured surface had been worn smooth(!), and it didn't quite work perfectly
on that.
Alex
Maybe I should have said solid, without holes, instead of
flat.
The skin does rub off the fingers and seems to collect in
the gaps.
news:c57elc$2os3rs$1@ID-149533.news.uni-berlin.de...
in message
a
get
| > in the ball socket.
cells :).
is flat.
Logitech one - have
| a flat base.
mirrors.
mouse mat where the
| on that.
| Alex
I can't decide between a vanilla moire pattern or a giant fractal!
I'm testing the algorithms now...
On Fri, 9 Apr 2004 19:35:28 -0500, "Jim Macklin" <p51mustang[threeX12]@xxxhotmail.calm> wrote:
>texture tho...
Bait for spammers:
root@localhost
admin@localhost
abuse@localhost
uce@ftc.gov
