[SOLVED] Orange case and temperature
Mar 16, 2019
21
Hi, first of sorry for my bad english I just have some question about cases and temperature.
I want a black/orange case but those I found are either old (you can't buy it anymore) or I don't like the look or it was a quiet case.
I know that quiet case get warmer then normal, like be quiet base 801 (most likely going to buy right now)
I wonder if 10 °C does something in the long run (years) when you are using it 12 h a day or more? or it doesn't matter so long you have enough fans?
I'm going to overclock some but not to much.
if it seems like a problem for me then I going to just paint a black case and design it my self.
I have check if everything fits for base 801 and it does.
you can send me a recommendation on a black/orange case with windows.
Thank for the replys
As long as you have good airflow those cases will perform well, over the life of your system. You need not worry over the "quiet" factor.
