I've seen several similar posts here but none seem to offer a solution except "sounds like you have a bad motherboard"..
I'll try make this explanation as simple as possible and hopefully someone has run into this and can point me in the right direction.
Issue:
Issue:
- Will only Boot with ONE RAM stick installed (in bank 1 of 2, closest to the CPU)
- When booting with both RAM sticks, I get permanent orange LED and it won't POST.
- Asus ROG Strix B40-I Gaming
- Corsair Vengeance RGB Pro (2 x 16Gb)
- AMD Ryzen 7 2700X
- Updated to very latest Asus BIOS - Version 3103
- Restored BIOS to defaults
- Tested with brand new, identical RAM. - Same result.
- Swapped RAM sticks between slots and changed up sticks with brand new sticks. - Same result
- Cleaned RAM and RAM slots with alcohol. No help.
- This used to be a Hackintosh, which ran perfectly with both RAM sticks, running Catalina etc etc.
- This single RAM thing has only happened after wiping the drive clean and installing Windows 10 64.
- I notice that inside the BIOS it's showing my RAM as running at 2333Mhz, not at its max 3200Mhz.
- I suspect it's a BIOS issue and not a hardware issue, given the testing with other brand new RAM. It "could be the motherboard" but it's fairly new!
