I had check if parts were compatible and they were but now an issue seems to pop up. Is there anything I should change or will it be fine. TIA.
https://pcpartpicker.com/list/k2Pb7X
I checked and there was no compaBest to ask this before ordering.
I didnt really have the cash to upgrade atm, and was told to cheap out on these parts as i could upgrade in the future.Looks compatible to me. Maybe go for a little less sketchy cpu cooler. Maybe a Hyper 212 or something instead? Also not really sure of about the ram
saving this to hopefully upgrade in the near future.https://www.newegg.com/western-digital-blue-sn550-nvme-1tb/p/N82E16820250135
Western Digital WD Blue SN550 1TB NVMe M.2 2280 SSD $99.99
+ $10 off w/ promo code SSDSEPT48, limited offer
10th gen cpu + B560 - this means one of M.2 slots will be non-operational.saving this to hopefully upgrade in the near future.
The Gammax 400 has been extensively tested and compared to the CM 212EVO, it will give you almost the exact same performance, especially for low wattage parts, you won't need more than a budget tower cooler.I didnt really have the cash to upgrade atm, and was told to cheap out on these parts as i could upgrade in the future.
