[SOLVED] "Other Devices" - Driver issues
brycehazen
15
Samsung 970 m.2 1TB
intel i7-10700k Comet Lake LGA 12008- core 3.8Ghz
Corsiar Vengeance LPX 32GB DDR4 288 pin 3600
EVGA RTX 2080 super
ASROCK z490 Phanrom Gamning 4/2.5G
Installed the above gear, Put my old SSD in with windows 10. Everything worked fine, used the rig all day. Next day I did a fresh install of Windows 10 on the M.2 and now there's devices that will not work. One of them being the Ethernet adapter. I used a USB to get the latest drivers, but no luck. The BIOS though, will connect to the internet and i updated the BIOS to the latest version. I have tried disable/enable, reinstalling drivers, manually updating the drivers fails. Rebooted several times in-between each change. Still cant get the drivers/devices to work.
I'm currently installing every driver from ARock's website.
That also didn't work.
If I can't figure it out by tonight, I guess I'll reformat??
I tried installing from a USB off ASROCK's website:
ME(v14.0.30.1 115_cons_sw_DCH)
LAN(v12.18.9.14w)
The devices that are not working are:
Ethernet Controller
PCI data acquisition signal processing
PCI device x2
PCI simple communications controller
SM Bus Controller
XBOX ACC
SOLVED:
thankfully there was a type-c usb port to connect my phone to get my computer internet access. I think clicked the devices that weren't working to let windows automatically look for the driver.
