Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Hello.
I have an Iogear brand 40 GB external hard drive, which connects to my
computer via either a USB2 or Firewire port. The drive is currently
formatted as one NTFS partition. When using either the USB2 or firewire
connection option, writing data to the drive causes the system to hang.
This event usually occurs when copying a group of files or folders, or when
performing a system backup.
I believe the problem may be with my Asus P4C800 Deluxe motherboard. With
this motherboard installed, my system has always had a problem properly
recognizing and working with USB2 devices. As indicated in the most
recently updated BIOS, the motherboard is supposed to recognize up to 8 USB2
ports on my system, but ever since I've had this board, my system has not
been able to properly recognize a USB2 device when its plugged into any of
the available ports built into the board, or the two ports that are at the
front of my tower case.
I bought a USB2 PCI add-on card, and that seems to work OK, in that USB2
devices plugged into it are properly recognized. Using the add-on card, my
system does recognize the drive OK. But the drive still fails when writing
data to it. I believe it also fails when reading from the drive. I get a
"Write Delay Failed" error message when the failure occurs.
I've tested the drive on two other USB2 compatible computers, and it seems
to work fine on them. I recently RMA'd the drive back to Iogear. After a
week or so of testing, they returned the drive back to me to me as being OK.
They either repaired or replaced it, and they also sent me new USB2 and
firewire cables, and a new power cord. But it still fails to work right.
Connecting the drive to the computer via the firewire port results in the
same eroor message.
In the BIOS, I have the USB option set to recognize USB2 and at the Hi-Speed
setting (as opposed to the slower Full Speed).
I also have a new USB2 Epson color inkjet printer (Stylus Photo R300)
connected to the computer via my USB2 add-on card. So far, the printer
works fine on my system (knock on wood.)
Any help would be greatly appreciated.
Thanks.
Rodney
Hello.
same eroor message.
Thanks.
Rodney
