P4C800-E Deluxe and PCI Serial ATA card
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard,alt.comp.periphs.mainboard.asus (More info?)
I have a P4C800E deluxe mobo with P4 2.8
Attached I have DVD Writer, CD Writer and DVD Rom drives
Also have 2* IDE PATA 120Gb HDD's which are spanned (1Volume)
PLUS I have 4 * 250GB SATA (NOT RAID) drives all connected to the mobo SATA
ports.
I wanted to add a further internal 300GB SATA Drive and an external SATA
drive in a SATA/USB2 enclosure.
So i bought a PCI SATA card with 1 internal and 1 external connectors.
HOWEVER, with the PCI SATA card installed the PC wont boot.
Is this because i simply CANNOT add any further SATA ports?
Any help much appreciated.
TIA
Darren
"Darren M Taylor" <darren@NOSPAMthemansionhouse.fsnet.co.uk> wrote in
message news:ch4qra$rg$1@news8.svr.pol.co.uk...
SATA
> ports.
Check BIOS settings for the Boot Configuration. Most likely the order gets
screwed up now that you have another controller installed.
Might also try the card in a different PCI slot.
I have a second Promise Sata controler running with this mobo
With 4 x IDE dvd/cdrom on first onboard ide controler
2 x IDE HD on second onboard ide controler
4 x Sata HD on onboard sata promise controler
and 1 x sata HD on pci sata promise controler
Upgrade your bios to version 1017 !!
previous versions have problems with the bootconfiguration
With previous versions, everytime when you add a HD or controler the
bootconfiguration screwed up
Suc6, Martin Zijlstra
"Noozer" <dontspam@me.here> wrote in message
news:9ysZc.295535$J06.231265@pd7tw2no...
> SATA
>> ports.
I have BIOS version 1017 already installed.
I checked the boot configuration, but as I had not actually even installed
any drives on the controller, there was nothing to change. and no reference
to the pci card.....
"Sharky" <martinz(nospam)@planet.nl> wrote in message
news:ch5ork$oso$1@reader13.wxs.nl...
>> SATA
>>> ports.
>> gets
