Archived from groups: alt.comp.periphs.mainboard.asus (
More info?)
So what is ASUS's answer to one of their flagship boards having a problem.
1. Have your dealer test it. They know less than me.....I.T. professional
for 14 years.
2. RMA it back here so we can take a couple of weeks sending you the same
board version again. Oh, that's worth while!
Well I'm unimpressed. I wonder how long it will take for a clue to filter
down to the techies at ASUS from the users in the real world who actually
know it's a problem.
I'm guessing a USB based microphone will have none of these problems and so
I may try one of those next.
All the best
Barry
"Barry" <BarryMW@NOSPAMHEREpacbell.net> wrote in message
news:4OBJd.15783$5R.1486@newssvr21.news.prodigy.com...
> Well I've sent the problem to ASUS support. They came back quickly but
with
> the standard refer to this page in the manual for the level control. I've
> replied yep, got that max'ed already. We will have to see what they can
do.
> Good news is that I googled and I not the only one that has noticed the
> problem.
> Thanks for the info
> Barry
> "Paul" <nospam@needed.com> wrote in message
> news:nospam-2501050259410001@192.168.1.177...
> > In article <nospam-2501050231340001@192.168.1.177>, nospam@needed.com
> > (Paul) wrote:
> > > In article <G5kJd.14690$wZ2.1137@newssvr13.news.prodigy.com>, "Barry"
> > > <BarryMW@NOSPAMHEREpacbell.net> wrote:
> > > > My P5AD2-E seem to have too little gain on the Mic input. I've the
> latest
> > > > drivers and tried several Mics but still too quiet. This is causing
> problems
> > > > with essential applications such as Counter Strike Source. Yes -
I've
> turned
> > > > up the gain in windows and Counter Strike.
> > > > Any ideas?
> > > > Thanks for any and all help.
> > > > Barry
> > If you have a better head for numbers than I do, compare an
> > AC97 chip, to the CMI9880:
> > ALC650, an AC97 audio chip. Data sheet version 1.28 . Page 10
> > has microphone volume of +12dB to -34.5dB in 1.5dB steps. On
> > top of that, there is the 20dB boost button. Max gain in
> > that stage is 32dB.
ftp://202.65.194.18/pc/ac97/alc650/alc650_data5.zip
> > The CMI9880 seems to only have gain in the "input widget".
> > It has 32 steps of 1.5dB and an offset of zero. This
> > implies a gain of from 0 to +46.5dB, and the rest of the
> > spec doesn't seem to have any attenuation capability.
> > The microphone in the ALC650 has a range of +32 to
> > -34.5dB, or a total range of 66.5dB .
http://cmedia.com.tw/doc/C-Media%20CMI9880%20Datasheet%20rev%200.99C.pdf
> > The CMI9880 just doesn't make a lot of sense to me.
> > Maybe someone else can explain this to me. A chip
> > that only has gain, doesn't make a lot of sense,
> > when you want to turn it down
> > Paul
