Panasonic KX-P1180 printing problems
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.print_fax (More info?)
The self testing on the printer tests ok. It will print out a test page when
I set up the printer ok. XP did not recognize the printer to set it up
automatically and I had to install it manually. I had one page print
properly from Corel. After that, it just prints a bunch of charachters and
it seems to load thebuffer in the printer up with garbage. Any ideas of
where the problem is and how to fix it?
Panasonic KXP 1180 printer is a Dot Matrix printer and retails for about $180
The drivers for that printer are in the WinXP DLL (Dynamic Link Library) to
manually install. Connect the printer to its parallel port and then go to:
Start>Control Panel>Printers and Faxes>on the left under Printer Tasks>
click Add a printer and just follow the prompts. Your printer has built-in
fonts, check on what yours is set to, it should be on Courier and powered ON
to install properly. When done, reboot your PC for the drivers to install.
Has this printer ever operated properly with this computer with the Windows
XP operating system?
If no:
The usual problem that gives the symptoms you describe is the setting for
the LPT port in the computer's BIOS. If set for EPP or ECP or ESC&EPP, it
can happen that the data is sent to the printer too rapidly.
The fix at your disposal is to change the setting for the port the printer
uses to standard parallel port. The language used for the setting differs as
between BIOSs. Look for something like SPP, bi-directional printer port,
standard or the like.
OK out and save the setting change.
Allow the computer to re-boot.
Let us know.
Tom
MSMVP
Windows Shell/User
"Hopeless" <Hopeless@discussions.microsoft.com> wrote in message
news:6C4FB9BE-BD4D-448A-A746-56855583341C@microsoft.com...
: The self testing on the printer tests ok. It will print out a test page
when
: I set up the printer ok. XP did not recognize the printer to set it up
: automatically and I had to install it manually. I had one page print
: properly from Corel. After that, it just prints a bunch of charachters
and
: it seems to load thebuffer in the printer up with garbage. Any ideas of
: where the problem is and how to fix it?
Tried that before. Doesn't work. It is set at Courier and power on. Thanks
for the e reply.
Do not quit so soon! Are you getting error messages and if any what do
they state? What does it do when you try to add the printer? Does XP find
the driver in its library? Please repost, some readers may be reading this
post and are having similar problems and could benefit from your results.
> for the e reply.
Yes. I have discovered that it will print with word perfect but converted
files from microsoft office just give a bunch of character and symbols.
Don't know why.
Definitely a problem somewhere. My computer had the explorer removed and
other items changed. Fortunately, back up took it back to good settings for
the program. microsoft downloaded the sp2 package yesterday and maybe that
will solve the problems. Spy bot, Ad Aware and microsoft anti virus all say
nothing is wrong.
Thanks for the reply. If I can only use word perfect to print, i can live
with that.
> If no:
> Let us know.
> Tom
> MSMVP
> Windows Shell/User
> when
> and
