[SOLVED] parts justified for 2700x
Dec 7, 2018
5
Hi Guys,
I have just built my first PC and the performance is amazing but it does not solve my real purpose of getting this built. I work with huge excel files with million rows that use vlookup and sumifs and hybrid of count and if functions. The reason for getting this PC was to get the work done faster but i am not getting much difference coming from a dual core I5 and 4 gb ram. My new build has:
Ryzen 2700x
B450M Mortar
8 GB 2666 MHZ g.skill ripjaw Vseries
240gb WD green M.2 SSD
Nvedia 710 2GB graphics card
Gigabyte 500W bronze certified PSU
I have overclocked the processor to 4.15 mhz however the ram cannot be overclocked. I notice a HUGE difference in performance from my previous laptop but i don't notice much difference in the excel calculation speeds which is the real reason this PC was built. Although I don't plan on using this PC for anything other than a workstation but i want the 2700x to run at its full efficiency after spending all that money.
Can anyone see a bottleneck anywhere which is most likely to slow down excel calculations or the PC in general. I can still exchange the parts. I don't plan on playing games or video editing so don't require a graphics card. Any recommendations will be helpful. Thanks
Varun
zyh1987
Respectable
Mar 16, 2018
2,091
386
due to the design of AMD cpu, their perform a lot better with dual sticks.
also when you mention you can't oc your memory, what exactly do you mean? can't post?
Dec 7, 2018
5
Was thinking of getting 3200 8gbx2 but my country only has trident Z RGB which is 210 usd here and i wonder if that would return value in terms of speed increase
Dec 7, 2018
5
My motherboard BIOS menu has the XMP profile option grayed out because the ram does not support overclock
Similar threads
