Pc build for 35000 rs help..
However, this is a build without monitor:
Rs. 42,000: https://in.pcpartpicker.com/list/C6W4TH
Rs. 37,000: https://in.pcpartpicker.com/list/zLmr8K
And these builds are with monitor:
Rs. 45,000: https://in.pcpartpicker.com/list/KQJMHN
Rs. 43,000: https://in.pcpartpicker.com/list/TDW4TH
Rs. 37,000: https://in.pcpartpicker.com/list/kQ4s7h
The builds of about 40,000 rupees are just a bit more expensive but if you can get that money you can get a decent gaming desktop. In the cheap 35k builds, I have a G4400 as the G4500, G4560 are too expensive in India. I hope you like my work..
Regards.
Seeking_Gamer_2
Commendable
Feb 29, 2016
218
Regards.
That build without monitor Rs. 37,000. There are few changes to it. First of all remove that CPU cooler as Pentium G4400 comes with a decent stock cooler. That B250 motherboard is not Rs.4,700 it is Rs.6,900(open Amazon link to get correct price). Change the RAM to single 8GB stick go for Crucial DDR4 1 x 8GB which is Rs.4,100. Throw in GTX1050Ti as it costs oly Rs.1,500 more. Don't go for Circle PSU it is crap. Go for Seasonic S12II 520W which is Rs.1,300 more but is very high quality PSU. Go for Corsair 100R case for Rs.500 more it has great quality and is spacious and easy to work.
Here is the list:
CPU: Intel - Pentium G4400 3.3GHz Dual-Core Processor (₹4465.00 @ Amazon India)
Motherboard: Gigabyte - GA-H110M-S2 Micro ATX LGA1151 Motherboard (₹4999.00 @ Amazon India)
Memory: Crucial - 8GB (1 x 8GB) DDR4-2133 Memory (₹4100.00 @ Amazon India)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive (₹3877.00 @ Amazon India)
Video Card: Asus - GeForce GTX 1050 Ti 4GB Phoenix Video Card (₹12499.00 @ Amazon India)
Case: Corsair - 100R ATX Mid Tower Case (₹3390.00 @ Amazon India)
Power Supply: Antec - BASIQ 650W ATX Power Supply (₹5455.00 @ Amazon India)
Total: ₹38785.00
Generated by PCPartPicker 2017-06-25 17:13 IST+0530
Seeking_Gamer_2
Commendable
Feb 29, 2016
218
Circle PSU is not crap, have you ever tried it? I own it, it is very good, I mean it might be the cheapest 80+ power supply. It is safer to get two sticks of RAM but that doesnt matter. And as for this power supply you are recommending, it is not even 80+ certified. How can you say Circle is crap? Really you are advising a 650W (not certified) psu for a gtx 1050 while 550w psu can run a 1080 too. Plus, there is no harm in getting two sticks of ram. Performance should be better along with the price, getting good-looking cases doesnt matter, and for these items, a spacious case isn't required!
Just being a local company does not make Circle bad, its products are great.
