Question PC build not working (no fans or leds on)
timlong
7
I have a Ryzen 3 1200, a MSI armour rx 570 8GB and an MSI B450-A Pro. I have built it all now and plugged it in and nothing works. When I click BIOS Flashback is flashes white three times but still nothing happens. Please help. (I am very new to all this and I don’t really know what I’m talking about tbh)
Hey Tim,
Have you tried making sure your RAM sticks are firmly put in place? Also are you getting any signal to the monitor?
It is definitely connected to the monitor , but nothing is showing up on it. And I am sure that the RAM sticks are firmly plugged in. Thanks
Sent from my iPhone using Tapatalk
So what exactly happens after you turn it on? (Don't press flashback)
If possible can you take a picture
Nothing, here is the photo.
Hey 1st thing, the ram is in the wrong slot. It goes second from the left (refer to the Manuel). The other is make sure your PC case pins are put in the right position to power on the device as the picture shows.
Does it matter if the RAM is in the wrong place?
