I have just finished building my PC, so I was doing a test before I cleaned up to see if it turns on and if all the parts are in correctly. I plugged everything in and pressed the PSU switch and computer switch. When I turned on the power supply my mouse's LED's turned on. The computer did nothing. It may be a problem with the front panel connectors, but I followed the manual so it should be right, although the manual said for the HDD PLED and RESET PLED positives are on the left, but the arrows on the connector are on the right. Anyway, no fans turn on and its like nothing happened. I've put all the power cables in right and my PSU is working. These are my PC specs:
Intel Core i3- 6100
with Intel stock CPU cooler
Asrock H170 Pro4s motherboard
Zotac Geforce GTX 750 Ti
G.Skill Ripjaws V 2x4 GB DDR4 Ram
Corsair Spec- 01 Case
EVGA 500 Watt PSU
Western Digital 1 TB Hard Drive
Also, this is my first time building a PC.
Intel Core i3- 6100
EVGA 500 Watt PSU
