Hi, first time PC builder here so apologies if I’ve done something silly.
I’ve just assembled my PC and attempted to power it on. The fans all come on (both the case fans and the AIO radiator fans, along with their ARGB alighting, but I get no LEDs lighting on the motherboard (including thE QLEDs which are meant to help debug boot issues). Similarly no screen signal (My screen is plugged into the motherboard HDMI, and I have no separate GPU plugged in at the moment to keep things simple).
Oddly, whilst I can power on with the PC’s power button (on the case), I can only make the PC switch off by flicking the PSU power switch off. If I turn the PSU switch back on within a few seconds of powering off, the fans come straight back on, without having to press the PC power button. If instead I wait 30 seconds between powering off at the PSU and then back on again, the fans don’t then come back on until I hit the PC power button.
The fans are all plugged through the fan/argb controller hub that came with the Be Quiet cooler.
Things I’ve already tried:
- checking the processor is properly seated (no change)
- removing all the memory and powering up without it (no change)
- checked the ATX power connector is plugged into the motherboard firmly
- praying to the hardware gods!
Hardware setup:
MSI AB50GL PCIE5 850W PSU
Asus Tuf Gaming Motherboard B650-Plus
AMD 7900x
2 x M2 PCI 4 Crucial SSDs (4gb each). 1 of these is in M2 slot 1 (the PCI 5 compatible slot), and another is in M2 slot 2. Is it ok to use a PCI4 compatible M2 drive in a PCI 5 compatible slot? I think the slots are meant to be backwards compatible
Be Quiet! Pure Loop 2 FX AIO
2 x 16Gb Kingston Fury Renegade DD5 6400Mhz Dimms (in sockets A2 and B2 respectively when I started this testing process, but currently removed)
Montech AirX ARGB case
Any advice or suggestions for troubleshooting steps would be gratefully received. Please ask if you need more info.
***THANKYOU***
Hardware setup:
AMD 7900x
***THANKYOU***
