See what it sounds like in mine, is as if a rotor was winded backwards. You know something like a beyblade winding on the launcher if you know what I'm talking about. It's one click when turning off. That's normal, and comes from the psu. If you are still concerned, you can do one thing. Take the PSU out, place it as far away from the mobo as possible (still connected) . And then turn the pc on and off see where it comes fromtbh cant know since sometimes i hear it from the psu and sometimes the motherboard, btw i removed the GPU and the clicky sound still there.
Happens to me when I turn it off. Comes from the PSU for me. I don't think it's a problem if you've been having it since day 1. If it's new it might be a problemNever heard this sound before, when i turn off my PC or turn it on, i hear a click sound, is that okay ? i can record if you want.
Yea it started to happen when i bought my new PSU.Happens to me when I turn it off. Comes from the PSU for me. I don't think it's a problem if you've been having it since day 1. If it's new it might be a problem
It's happened everyday since you got the PSU? Then it probably is the PSU. Should be fine. Try checking if it's from the PSUYea it started to happen when i bought my new PSU.
tbh cant know since sometimes i hear it from the psu and sometimes the motherboard, btw i removed the GPU and the clicky sound still there.It's happened everyday since you got the PSU? Then it probably is the PSU. Should be fine. Try checking if it's from the PSU
ill try that later and ill reply back to you.See what it sounds like in mine, is as if a rotor was winded backwards. You know something like a beyblade winding on the launcher if you know what I'm talking about. It's one click when turning off. That's normal, and comes from the psu. If you are still concerned, you can do one thing. Take the PSU out, place it as far away from the mobo as possible (still connected) . And then turn the pc on and off see where it comes from
