Question PC Constantly Blue screening. PLEASE HELP!
Rezii
Great
Feb 21, 2022
100
Hey, so ever since I've had my Ryzen 5 2400G 750w PSU 16gb ram crucial ballistix ga-ax370,gtx 1050ti PC, it has quite frequently bluescreened with error "WHEA_UNCORRECTABLE_ERROR".
I looked on Youtube and saw a few videos saying scan hard drive and memory, did both and both said no issues. I really need this fixing since it just happened FOUR times to me in the past 20 mins.
I am not saying that.
Do you have to be doing anything specific to get the error?
Ryzen 5 2400G - unsure if it passes
750w PSU - what make/model?
16gb ram crucial ballistix - passes memtest
ga-ax370 - there are no tests for any motherboard
gtx 1050ti
NVMe - seems okay. doesn't work with magician but then its not listed as supported by it.
Need to know if CPU passes.
We can't test MB so you test everything else and use a process of elimination. If everything else passes, it could mean its MB.
I suggested a repair store as they might have spare parts they can swap in to test your stuff. Or put your parts on theirs.
Oh okay, thank you and sorry for the carry on. I'm not really sure of the psu brand, on ebay just said 750w PSU and also i tried to look a few months ago and i just couldnt see bcus i took off the back panel and it was being covered by tons of stuff.
1 & 3 or 2 & 4 would work on your board - page 10 - https://download.gigabyte.com/FileL...ing5_e.pdf?v=a3aa0ad9bbfa977d73ad401681f0f0a4
A2 & B2 aren't even choices.
they all DDR4_1 to DDR4_4
PSU could be cause too but it seems to be a mystery now. How much was it?
I can't tell really what cause is as without dumps I am flying blind.
correction
4_1 & 4_2 are one channel
4_3 & 4_4 are another channel
doesn't help physical order on board is
4,2,3,1 from left to right away from CPU
So you appear to be in DDR4_4 & DDR4_3 which is one of the channels.
Reactions: drivinfast247
