Hello, I recently build my first new PC and been using it for 2 months.
And I'm constantly paranoid that it's over heating. This is my spec:
CPU: Intel Core i5-7600K -
GPU: Nvidia GTX 1060-6GB -
SSD: Samsung 750 EVO 250GB -
HDD: Toshiba DT01ACA200 2TB -
RAM: HyperX Fury DDR4 2133 C14 2x8GB -
MBD: MSI B150M GAMING PRO (MS-7994)-
CPS: VS Corsair 650W
I'm using a NEXTYDE X2 Case http://www.x2products.com/computer-cases/nextyde-x2-6021b-ce-r/
And a Cooler master Hyper 212 EVO.
I got my CPU fan pushing the air throught the heatsink and then out of the back of my case.
My case came with a fan that has a 4 pin molex conector and I hooked it up to the CPS and installed it infront, it also is turned on by a button next to the power button mostly I keep it off.
Anyhow my case heats up while gaming and I'm paranoid isn't it too much I want the parts too last so I was thinking adding extra fans. I tried testing to see how hot it gets with some software but with little luck.
My mobo has 2x4pin system fan plugs and I'm thinking off adding those 2. I'm thinking to put one on the top of the case to suck the air out, right above the CPU's heat sink and another maybe in the back behind heat sink. Now won't there be too much going out ?
Also the fan that is turned off and off by the button bothers me a bit. It's a bit loud when I turn it on and it came with the 4 pin big molex I cant plug it direcly to my mobo. Can anyone maybe provide me with an adapter name so that I could plug this fan directly into the mobo instead.
Or maybe can someone suggest better placements for my fans.
Insides picture. https://www.dropbox.com/s/1c4yoxplybabu4u/20170310_230251.jpg?dl=0
This is what I want to do https://www.dropbox.com/s/b0t7qoba557q3s0/1.jpg?dl=0
