Hi. I was playing red dead redemption 2 on my recently built pc and suddenly my pc crashed with blue screen. I turned everything off and noticed that all the components were very very hot. Then i let it cool for a while and turned it back on. Now the problem I'm facing is my m.2 drive is showing in bios but when i try to boot from it it says 'reboot and select proper boot device' so my guess was that maybe Windows got corrupted. But when i tried to install Windows the m.2 drive is not showing in Windows setup at all. In fact there are no drive visible in window setup option. Now one more thing i want to mention is that my m.2 has rgb lights on the heatsink and those rgb lights are working fine. M.2 shows in Bios but not in Windows setup.
And I've also installed windows in different ssd drive but again m.2 drive is not visible in disk management aswell.
I'm really confused is my m.2 gone bad or there is a way to fix it? I've tried every possible solution that i could find on google from changing bios settings or repairing windows through setup. None of them worked for me
My setup :
Cpu : ryzen 2600
Gpu: rx5700xt
Mobo: Gigabyte b450 pro wifi
M.2: XPG spectrix 240g RGB 250gb
My setup :
Cpu : ryzen 2600
Gpu: rx5700xt
