Question PC Crashes not overheating
BisdakIKobe
47
Hello all I am having a problem with my pc randomly crashing during some of the more intensive games I play (Rust and R6Siege) sometimes on other occasions once while I was watching Netflix
the thing is it just freezes as if I have overclocked the cpu and it wasn't stable but sometimes my GPU shuts off with no signal to my 2 monitors (1 DP and 1HDMI) and audio like Discord keeps running but the mic doesn't keep working and I have to force restart with the reset button or by killing the power.
and now how it started, it started after I decided to change my GPU's thermal paste and I actually did a pretty bad job putting a bit too much or it was a bad brand and I had worse temps and I thought for a while thats why it happened because i reapplied it 2-3 times but now I have reapplied another thermal paste I have cleaned my case completely taken the PC a part flashed the bios flashed the GPU bios tried with with lowering my CPU overclock switched up ram sticks (which had worked fine prior to that) and to add it was 2x4GB kit and 2X2GBkit but they were different brands now its a 2x4 1x2GB and 1x8GB.
also I ran a CPU and GPU stress tests simultaneously
My System:
MSI P67A-GD65 B3
I5-2500K OC 4.5Ghz (worked fine before taking the GPU a part) never goes over 65 degrees on air cooling
Slot 1 :1x8GB I don't really know the brand but Part Number is M2X8G64CB8HC4ND-G its 1600Mhz
Slots 2 and 4: 2X4GB GSkill F3-12800CL9-4GBXL 1600Mhz
Slot 3: 1x2GB Corsair VS2GB1333D4 1333Mhz
GTX 660TI PNY Enthusiast Edition
on my quiet MSI Afterburner I run it at around 70-72 ish degrees and on my gaming one it runs at max 65-66
Be Quite System Power B9 600 Watt 80+ Bronze
x1 Kingston A400 480GB Boot Drive SSD
x2 Samsung HD403LJ HDD
x1 Toshiba MQ01ABF050 HDD
I have reinstalled Windows around 5 times now with all fresh drivers and everything
PLEASE HELP
Yes I will do that I normally have the msi afterburner overlay and I think it also logs them
Btw the numbers given in the main thread are stress test temps so thats full load temps
